How to remove inner tail lights on 95/96 trunk
Old Mar 2, 2005 | 06:14 PM
WHOS UR DADDY's Avatar
How do i remove the inner trunk lights on the 95/96 trunk? Pics and instructions would be appreciated.
Old Mar 2, 2005 | 06:55 PM
Zach95SE's Avatar
If I saw this an hour ago I would have taken pics. I just did it for paint tomorrow. Its real easy though just open the trunk and there a four studs with nuts on them. Take off the nuts and pry it out a little and it should push right out.
Old Mar 2, 2005 | 07:10 PM
darrick's Avatar
Dallas Nissan Enthusiast
also if you have a heat gun youcan heat the area arount the bolts and it will come out with a lot less prying
Old Mar 2, 2005 | 07:18 PM
I really need pics, cause its not for me but for someone who is not a member. I tried explaning it from what I remember but he doesnt get it. I remember there being four little nuts and then you just push it out. Anyone who can get pics, that would be great
Old Mar 2, 2005 | 07:40 PM
MSmax96's Avatar
Just found this...hope it helps
http://www1.autozone.com/servlet/UiB...3d801f5c81.jsp
Old Mar 2, 2005 | 08:03 PM
thats cool, except its the outside lens and i need the inner lens
Old Mar 2, 2005 | 08:52 PM
Terran's Avatar
Don't scratch up my trunk .
Here's the instructions for a 97-99 from VQpower (from the R/C coversion). I would bet they're the same for 95-96.
"0. The first step in modifying your taillights is to remove the taillight from the vehicle. Begin by removing the interior lining in the trunk. Some of the tabs that hold the lining in require a flat head screwdriver while others come off with a Phillips screwdriver. There are 2 plugs that need to be unplugged from the tail light. They both have white connectors. There are also some plastic pieces that hold all of the wiring to the nut. These may be tough to yank off. I used a pair of pliers to pull them off. There are 4 8mm nuts that hold the taillight in. Remove these using an 8mm deep socket. The only thing holding the taillight is some black sticky adhesive. There are a few ways to get the taillight out. One method is to gently heat up the adhesive using the heat gun so that the adhesive softens. Then push on the taillight. Another way is to gently tap on the 4 studs that hold the taillight in the vehicle. Lastly you can push the taillight out of you are strong enough. Place the bottom of your palm on the flat part of the taillight and push hard! Be careful of the adhesive so that it does not get on your hands or the taillight."
If your cousin doesn't have a heatgun then I hair-dryer should work too.
I realize it would require a level of trust, but if your cousin can't get them out you could just me the trunk and I'll take them out and send 'em on there way.
Old Mar 2, 2005 | 09:33 PM
Terran, you got pm
vingodine
45
May 21, 2016 12:46 PM
tommy20020
Jan 6, 2016 04:05 PM
4doorGTR
Sep 11, 2015 04:09 PM
A32goldylocks
Sep 2, 2015 06:39 AM
220k+ A32
Aug 17, 2015 03:57 PM
