Clutch pedal sticking help!!
Old Mar 6, 2005 | 10:00 AM
99maxx-on19's's Avatar
Well my clutch pedal is starting to stick to the floor then pop back up.I've been running an a c t stage 2 clutch and heavy duty pressuer plate,thats been in the car for maybe 30K miles.And some say it the pressure plate,can anyone confirm this thats had this problem?Also dont want a performance clutch like this anymore,can some one recommend a lighter more reliable clutch?
Old Mar 6, 2005 | 10:08 AM
Akumachan's Avatar
I never narc'd on nobody.
did you check the clutch fluid? if theres a problem with the hydrolic system, the pedal will stick. i dont know about a pressure plate causing it, ive never heard that before...
Old Mar 6, 2005 | 11:30 AM
MDeezy's Avatar
Yea I'd check you fluids sounds like your low and have a leak somewhere.
What mods do you have depending on what you have that can help determine what type of clutch to get depending on the amount of power your putting down.
Old Mar 6, 2005 | 11:44 AM
PAREDLINE's Avatar
First check your slave cylinder. Theyre about 20 bucks I'd change it anyway. It is the most likely culprit. If that doesnt work, then check the clutch master cylinder.
You cant really check it. I'd just change that too. You have a hydraulic problem somewhere.
My money is on the slave cylinder because theyre wimpy in maximas.
Old Mar 6, 2005 | 01:49 PM
quasidynamic's Avatar
Same thing happened to me a couple months back. I changed the slave cyl and the clutch line and bingo. problem solved for $50. I recommend you get the stainless steel clutch line if you are going to replace it. there's a GD for one right now, only $25.. which is $2 more than i paid for an OE line.
Devin
Old Mar 6, 2005 | 02:11 PM
mansurxk's Avatar
check the clutch line for a leak, they tend to leak, mine did the same thing, i had to refill the cylinder and re-bleed the system. www.motorvate.ca has the problem documented
Old Mar 9, 2005 | 03:08 PM
Ok thanks i'll do that first it sounds more like it since some of u seem to beleive thats the problem.And also the fluid is full and is not leaking..
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
