Changing Clutch
Old Mar 7, 2005 | 07:12 AM
krue92's Avatar
Changing Clutch
I am going to be changing out my clutch on my 95SE this weekend. I was wondering if there is anything special that I need to know or any info that would help me do it. Also do I need any other parts besides the clutch kit? Thanks.
Old Mar 7, 2005 | 07:24 AM
nismology's Avatar
Buy a haynes manual.
Old Mar 7, 2005 | 07:34 AM
krue92's Avatar
I got one.
Old Mar 7, 2005 | 07:39 AM
Bobo's Avatar
I have a 95 SE, 5-speed as well. How many miles on the clutch? Any problem with the differential bearing yet? I only have 57,350 miles on my car, mostly highway, and don't drive it like I stole it so I suspect I will be some time down the road with either of these problems.
Old Mar 7, 2005 | 07:42 AM
unixadm's Avatar
Get a manual - but you can also see some of the tips I posted when I did the transmission in my 95 SE this weekend. I went with a '01 transmission and all factory Nissan parts.. from the new flywheel to the clutch and pressure plate.
http://forums.maxima.org/showthread.php?t=384142
Old Mar 7, 2005 | 07:43 AM
krue92's Avatar
I have 140k on the car. I bought it with 120k and the clutch was starting to slip. I don't know if there was a differential bearing problem prior to me owning it, but I have not had a problem. They always say it was around 60k when people had problems with them.
Old Mar 7, 2005 | 01:03 PM
nismology's Avatar
Replace the rear main seal while you're in there.
Old Mar 7, 2005 | 01:19 PM
s0ber's Avatar
Old Mar 7, 2005 | 01:31 PM
Tjd135's Avatar
be carefull that u install all the sensor, and make sure the ground is bolted back up.. I got a problem with my car after replacing clutch, now the car takes like 10-30 min to start sometimes.. N i dunno what it is.. Good luck
Old Mar 7, 2005 | 03:43 PM
krue92's Avatar
So when taking the tranny off you don't have to remove the y-pipe or the engine center member?
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
f.matejaiii
Sep 21, 2015 12:09 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
