99 Maxima Vibration In Front End Help!!
Old Mar 7, 2005 | 02:32 PM
traderfjp's Avatar
Hi,
I bought my Maxima new in 99. I was doing the brakes and the jack slipped away and the rotor landed on the asphalt. Ever since that time the car will vibrate when I go over 60 mph. The force of the car landing was squarely on the rotor. Nothing else hit the pavement. I'm wondering if I screwed up my CV joint and axle. Should I replace these parts. I tried balancing tires, new rotors, with no luck.
Thanks in advance
Old Mar 7, 2005 | 02:43 PM
askorbik's Avatar
did you try front wheels alignment?
Old Mar 7, 2005 | 06:23 PM
traderfjp's Avatar
No. But the car doesn't pull it just vibrates. Do you think this could be the problem?
Old Mar 7, 2005 | 06:31 PM
bullfrog's Avatar
if you've already replaced the rotor, i would say the next step is to replace the control arm. it's section 10-7 in the Haynes manual. try ebay for a control arm at a decent price.
Old Mar 7, 2005 | 06:35 PM
njmaxseltd's Avatar
A direct impact to the rotor will cause damage to the hub and bearing assembly.
Thats most likely the cause of your vibration.
Old Mar 7, 2005 | 08:00 PM
traderfjp's Avatar
I found a great website that shows the removal of the hub and front bearing. The site is www.motorvate.ca My other problem is that I don't know what side has the bad wheel bearing. Is there a way to diagnose this. It's not apparent which side has the bad bearing when driving? My Max has 100k and I dropped it on the rotor at about 30k so I'm lucky it has lasted this far. After checking out the Haynes repair manual the bearing sound slike a good bet. Thanks
kingw323
20
Oct 21, 2015 08:36 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Balkins
Aug 12, 2015 06:39 AM
Samedi
Aug 12, 2015 01:54 AM
laparka66
Aug 6, 2015 09:36 AM
