i just got a key fob off of ebay now how the hell do i program it?
Old Mar 8, 2005 | 06:30 PM
2 Da Max's Avatar
yes could someone please let me know how it works?
Old Mar 8, 2005 | 06:31 PM
bigtimber's Avatar
stickies...
Old Mar 8, 2005 | 06:49 PM
2 Da Max's Avatar
you got to be shieting for real?
Old Mar 8, 2005 | 06:52 PM
MDeezy's Avatar
its in there takes 2 mins literally
Old Mar 8, 2005 | 06:55 PM
2 Da Max's Avatar
LOL i cant find it!! MDeezy help me
Old Mar 8, 2005 | 06:57 PM
bigtimber's Avatar
from How to's:
How to Program OEM Alarm Key Fob Remote
Couldn't find this anywhere and thought it might be handy to post.
To program the remote(s) follow this procedure
1. Close and lock all doors with power door lock switch on driver's door.
2. Insert and remove the key from the ignition more than 6 times within 10 seconds. The hazard warning lamps (both turn signals) will then flash twice and the original codes will be cleared.
3. Turn ignition key to "ACC" position.
4. Push the "Lock" button on the new remote controller once. At this time, the car learns the new ID code. The hazard warning lamps (both turn signals) will then flash twice.
For additional remotes continue below else go to step 9
5. If you need to activate additional remote controllers, manually unlock the driver's door only then lock again with door lock ****.
6. Push lock button on the additional remote controller once.
7. Hazard warning lamps (both turn signals) will then flash twice and additional remote is programmed.
8. For additional remotes, go back to step 5.
9. Open driver's door to exit programming state when done.
NOTE: Only a maximum of 4 remotes can be programmed to any ONE car.
Old Mar 8, 2005 | 07:02 PM
MDeezy's Avatar
^^^ He found it, before I got to it. Enjoy that new fob.
I love holding down the unlock button and winding down my windows, people are still amazed by that
kbmaxima's Avatar
was this a joke mr. 3160 posts? really...
Old Mar 8, 2005 | 07:03 PM
MDeezy's Avatar
hey we all dont know everything. Other wise we wouldnt have this forum, we'd all just have cardomain sites.
Old Mar 8, 2005 | 07:05 PM
2 Da Max's Avatar
wow it was in the stickies ive never really looked at the stickys for a long time. they got some good info their.
o another thing is my led security light stop working wtf? i changed the led and still no luck
Old Mar 9, 2005 | 03:06 PM
2 Da Max's Avatar
hey guys it doesnt work wtf?
Old Mar 9, 2005 | 03:12 PM
Black Maxima
Are you doing it right? HAHAHA Took me a bunch of tries to get it.
Old Mar 9, 2005 | 03:38 PM
MDeezy's Avatar
Did the hazard flash after your programmed it.
also make sure all doors are properly closed it wont work if they arent.
Old Mar 9, 2005 | 04:55 PM
MAXRB8's Avatar
Maybe your new fob is a POS, do you have an old one that still works? You could try reprogramming your old one and follow the sequence with the new to be sure you are doing it right.
Old Mar 9, 2005 | 05:17 PM
bigtimber's Avatar
check the battery....?
Old Mar 9, 2005 | 08:15 PM
2 Da Max's Avatar
the battery should be good, i see the hazards then i turn it till all the acc stuff come on then i press the lock button and nutting happens
Old Mar 10, 2005 | 04:30 AM
2 Da Max's Avatar
what could be the problem?
Old Mar 10, 2005 | 08:23 AM
Makavelidadon's Avatar
how do you do that? does that come stock? or do i need to specially program my remote to do that?
Old Mar 10, 2005 | 02:52 PM
MDeezy's Avatar
try it again
get into the car,
lock all door (with switch on the door)
put in and out key till you see hazards flash
turn to acc, push the button (push it hard maybe it need to be pushed in hard)
you should see the hazrds flash,
then take out key open and close door
should work. If it doenst work then it must be the battery cause everything else is working except for when it get to the point for you to push a button on the fob. I believe radio shack should have the appropriate battery.
Old Mar 10, 2005 | 06:24 PM
2 Da Max's Avatar
accesory is when all those little lights on the dash light up right? because after that part i dont see the hazards flashing again
Old Mar 10, 2005 | 06:48 PM
Igobuk's Avatar
"Accessory" is labeled on the ignition switch - ACC
It's when the radio turns on but not when the dash check lights turn on.
Old Mar 11, 2005 | 04:27 AM
2 Da Max's Avatar
oo ok i guess i was doing it wrong
litch
123
Jan 4, 2024 07:01 PM
Fbana41
Aug 29, 2016 12:18 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
RealityCheck
Oct 2, 2015 06:34 PM
