Alarm
Old Mar 9, 2005 | 12:16 PM
SDB318's Avatar
Alarm
to do the alarm beep mod. y do u have to remove fuses? do u put the back in? and where does the relay go?
Old Mar 9, 2005 | 12:18 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
you remove the fuses just to be safe. Put them back when you are done. I mounted the relay right next to the other one. By the way, the beep is failry quiet, you may want to try a louder one from radioshack.
Old Mar 9, 2005 | 12:28 PM
SDB318's Avatar
what one do u have?
Old Mar 9, 2005 | 12:46 PM
Business810's Avatar
I don't think you need the relay as long as you are using the smaller buzzer. I believe it's the model 273-060 (it's the one in the vqpower write-up). I've had it set up this way since last summer and everything works fine.
Also, if you put it under the bumper outside of the trunk it will sound a lot louder. That's how I have it. I just zip tied it to something under there, don't remember what though.
Old Mar 9, 2005 | 01:04 PM
SDB318's Avatar
how did u get uder the car then
Old Mar 9, 2005 | 01:19 PM
When you're looking at the wires you have to splice into in the trunk, there should be a rubber grommet that takes other wires out of the car nearby. I ran some wire through that, it comes out under the car inside the bumper. I soldered that to the wires for the buzzer then covered up the connections so they'd be waterproof.
Old Mar 9, 2005 | 03:01 PM
MAXRB8's Avatar
Hands & Knees for 4x4 Max or creeper if you're lowered.........
Sorry couldn't resist! seriously... you don't need the relay
Old Mar 10, 2005 | 11:57 AM
SDB318's Avatar
what did u use to cover it up with
Old Mar 10, 2005 | 04:29 PM
I shrinkwrapped plastic over the bare wires with a heat gun, but you could also use electical tape I suppose.
kmitchel
Oct 28, 2015 09:46 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
RussMaxManiac
Jan 3, 2001 06:41 AM
RussMaxManiac
Jan 3, 2001 05:40 AM
