Knock Sensor relating to performance
Old Mar 11, 2005 | 02:45 PM
98 GLE's Avatar
I just got a 0325 code back which was knock sensor 1 circuit malfunction. I have noticed since i got the car that right off the line if i power brake to 2 and drop it my car hesitates, and also at around 3k my car loses a little bit of power. I was wondering how much of this could be blamed on the knock sensor. And if i were to buy it and replace it myself how i would go about doing that.
Thank you for any help you can provide,
Mike
Old Mar 11, 2005 | 02:46 PM
ShRapNeR's Avatar
http://forums.maxima.org/showthread.php?t=72447
Old Mar 11, 2005 | 04:07 PM
98 GLE's Avatar
I found this on ebay is this the right part number? Nissan Part #22060-30P00
Old Mar 11, 2005 | 04:22 PM
BigLou93SE's Avatar
IIRC, yes.
Old Mar 29, 2005 | 11:10 PM
98 GLE's Avatar
I have officially got my knock sensor in!!!! I still experience a serious lag before about 3000 RPM's. I didn't torque the bolt. If i don't get it to 20 ft lbs. will that make a big difference?
Old Mar 30, 2005 | 03:34 AM
dgeesaman's Avatar
Maintenance Monster
No, as long as it's tight enough to hold it down well.
I used a universal jointed socket and a 14" extension, and had no trouble putting a little torque on it. What did you use?
Old Mar 30, 2005 | 02:53 PM
98 GLE's Avatar
I used an 1/8" dr ratchet handle and a 12mm socket. I found that if I put the socket on first then set the ratchet into the socket it was easier. I didn't use any extension.
Am I misinformed or is replacing a blown knock sensor not supposed to increase power below 3000 RPM's because if anything it seemed like it helped more around 3000-5500 RPM's. I feel a serious pick up in power at almost exactly 3 a little before.
ballerchris510
Sep 23, 2015 08:46 PM
JoshG
51
Sep 21, 2015 10:41 PM
ac max 92
Sep 17, 2015 07:35 AM
