5 Spd Gear position switch
Old Mar 12, 2005 | 10:35 AM
MaximA VlaD's Avatar
as we all know we remove the gear position switch (aka reverse light switch) to drain our 5-spd. but it is a plastic piece, and because of weather and dirt it sometimes cracks, as mine did. and now my reverse lights do not work. does anyone know exactly how the switch works so i can fiddle with it? the only part that broke off is the lip that the bolt goes through to hold the switch in the gearbox. thanks for your help.
Old Mar 12, 2005 | 11:00 AM
quasidynamic's Avatar
That's odd, ive never heard of removing this... i changed my gear oil without removing it... Wish i could help ya put it back together. A simple switch cant be an expensive part tho, prolly $25 tops at the stealership...
Devin
Old Mar 12, 2005 | 12:23 PM
Devin
yeah, its about $27 at the local 'StealerShip" haha. but i wanted to see if anyone knew how the thing works just for future reference if i r&r this one, which looks like what i will have to do. thank for the reply quasi.
Old Mar 12, 2005 | 12:26 PM
oh, and how did you drain yours?? my haynes said to remove the drain plug, but the switch is pretty much the lowest point in the gearbox, so i used that. plus i couldnt figure out which one was the plug they were talking about. Pics usually help, but not in this haynes issue.
Old Mar 12, 2005 | 03:49 PM
Chief Brody's Avatar
Drain plug is on the the passenger side end of the tranny. You can't fit a socket in there so many people choose to instead use the shift position sensor. I would try to get the drain plug first just to not risk damaging the sensor.
Old Mar 12, 2005 | 04:05 PM
anyone know how exactly does the sensor work? and are there any other places to get it aside the dealer? thanks.
Old Mar 12, 2005 | 08:21 PM
oldngivout's Avatar
Willing to learn
It's not really a sensor, but a set of contacts that make the electrical connection for the reverse lamps and the neutral position.
It has three positions:
reverse
neutral
evrything else
Actually the part inside the transmission moves across the face of this part, depending on which gear is selected. That is why they wear out. Constant movement, every time you shift into reverse or neutral.
Old Mar 13, 2005 | 12:40 AM
good info. thank you
Old Mar 13, 2005 | 06:55 AM
vortechpower's Avatar
reverse
neutral
evrything else
If thats not a sensor, what is?
Old Mar 13, 2005 | 07:15 AM
oldngivout's Avatar
Willing to learn
OK, technically it is a sensor. I was merely trying to explain its function in simple terms.
It seems that some people when hearing the word "sensor" automatically think of some complicated electrical device that is just there to turn on the check engine light.
Old Mar 13, 2005 | 11:16 AM
american components, russian components, sensors, switches... what is the difference.. all made in taiwan!
James92SE
142
Jan 2, 2024 09:23 AM
jsmith24
Feb 1, 2016 12:35 AM
James92SE
Oct 8, 2015 04:57 PM
220k+ A32
Sep 23, 2015 03:38 PM
dcardello
Sep 3, 2015 11:44 PM
