CamShaft Position Senor (REF)
Old Mar 12, 2005 | 08:16 PM
SDB318's Avatar
CamShaft Position Sensor (REF)
my check enginge light came on and i am having trouble starting the car. so i read the code and came out 0407 camshaft position senor (ref). would this have a problem starting the car.
thanks
Old Mar 12, 2005 | 08:45 PM
PAREDLINE's Avatar
Yes. it would
Old Mar 12, 2005 | 08:49 PM
SDB318's Avatar
is it hard to replace i mean can i do it myself
kc10fish's Avatar
EOM need you read more
Old Mar 12, 2005 | 08:52 PM
PAREDLINE's Avatar
Its not hard at all. its a little plastic sensor that is under your crankshaft pulley. 2 10mm bolts, pull off the harness, and its out.
Make sure you specify the REF sensor when you go buy it
Old Mar 12, 2005 | 08:53 PM
SDB318's Avatar
cool dude thanks
eom?
Old Mar 12, 2005 | 09:02 PM
kc10fish's Avatar
end of message / no more
Old Mar 13, 2005 | 02:31 PM
SDB318's Avatar
the man at the local auto parts said i can just clean it out to see if that works. but the only thing is i just cant get my fat *** under the car
Old Mar 13, 2005 | 02:33 PM
PAREDLINE's Avatar
Then you dont need the car. Just walk everywhere and burn the fat.
Its a blessing. Dont fix it
Old Mar 13, 2005 | 02:36 PM
SDB318's Avatar
funny dude but would it help if i just cleaned it out though
Old Mar 13, 2005 | 03:03 PM
SDB318's Avatar
can anybody help me
Old Mar 13, 2005 | 03:19 PM
gabex's Avatar
Im not sure.. I had the CEL and I bought the part, brand new, never used in box, and my light went away...
If you do decide that you need it, I can sell it to you..
Let me know what you find out.
Gabe
Old Mar 13, 2005 | 03:24 PM
SDB318's Avatar
what kind of problems did u have and how much was it brand new
Old Mar 13, 2005 | 04:28 PM
gabex's Avatar
My car would crank forever but not start..
I paid $55 plus $7.50 S/H.
Old Mar 13, 2005 | 06:33 PM
SDB318's Avatar
where is the Camshaft Position Sensor(REF) located
Old Mar 13, 2005 | 08:14 PM
SDB318's Avatar
come on guys i need help my car will not even turn over. i just wanna know where it is located
Old Mar 13, 2005 | 09:02 PM
adithius's Avatar
Well your fat *** should get a lift/floor jack.
The sensor you are looking for is on the oil pan, below your big pulley. To get to it lift the car up, remove the passenger front wheel, remove the plastic engine splash cover by the oil pan, and there it is. Take it out and clean it.
It is highly unrecommended that you use your factory lift in the trunk, but if you really need to be sure to put the parking brake on and try not to kill yourself. The best thing to do is get a 3ton floor jack and jack stands.
I believe you should clean it with electronic parts cleaner (Found at any parts store).
Old Mar 13, 2005 | 09:22 PM
SpeedyMaxima's Avatar
Its nothing serious on my brothers 97 maxima had same problem,and its located on the right side where the pulley is.
Old Mar 13, 2005 | 09:26 PM
Just buy a new one,i dont think to clean it is gonna help
Old Mar 14, 2005 | 06:36 AM
SDB318's Avatar
from what i heard it is not located under the car
Old Mar 14, 2005 | 09:07 AM
gabex's Avatar
well then maybe you know more about it than us
Old Mar 14, 2005 | 09:16 AM
adithius's Avatar
It's not really under the car. It's off on the side. The biggest problem is that your wheel will be in the way, so it is best to get the wheel off and the car lifted.
Old Mar 14, 2005 | 09:48 AM
chenzarino's Avatar
you don't need to jack up the car at all. turn your wheel all the way to the right. remove plastic wheel well cover. locate sensor above oil pan below flywheel. make sure wiring is connected tight. if so, remove and clean sensor. if car still wont start, then replace it.
Old Mar 14, 2005 | 10:33 AM
its supposed to be under the car,because i was watching how mechanics changed my brothers sensor
Old Mar 14, 2005 | 11:33 AM
PAREDLINE's Avatar
Look up. You guys need to read and not complain when someone doesn't reply to your post in 5 mins.
It is under the CRANKSHAFT PULLEY. A little Plastic Sensor that sorta looks like a T.
Now go out and change it. You dont need to take the wheel off. You might need to jack up the car or park it up on a curb or something.
Old Mar 14, 2005 | 11:35 AM
PAREDLINE's Avatar
That is the POS sensor. not the REF. The REF is on the passenger side. The POS sensor is on the other side of the engine.
Old Mar 15, 2005 | 09:04 AM
twiggy144's Avatar
Camshaft sensor is not the same as crankshaft sensor. These are 2 different sensors. The camshaft is accessible from the top, the crank from the bottom.
Old Mar 15, 2005 | 10:26 AM
chenzarino's Avatar
I was referring to the passenger side, where the oil pan is, the flywheel is, and where the sensor is. The other sensor is on the transmission bell housing and can be reached by going directly underneath the front of the car. They can both be accessed and removed easily without jacking up the car or taking anything off other than the splash guards. I know this because I have checked both of them this way.
Old Mar 15, 2005 | 12:24 PM
mechanicaljoint's Avatar
Same discussion above .. check out
http://forums.maxima.org/showthread.php?t=388045
Old Mar 15, 2005 | 12:29 PM
thanks
2 Thoughts...
1. The 0407 corresponds to the CRANK Position Sensor - REF. Not the CAM shaft.
2. Buy a Haynes Manual for starters. That way you won't get flamed as much.
TallTom
57
Oct 14, 2025 05:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
