leave car running while refueling..is this bad?
Old Mar 14, 2005 | 06:46 PM
  #41
eturnl
Originally Posted by MaximA VlaD
supposedly while talking on a cell phone, fuel vapors may build up around you and your gas tank as you are fueling your car (running or not). and as any electrical device, some may have a short, or even a small spark when you press a button that could lead to an explosion of all the fuel vapors around you... if you ask me, i think that is a thing of the past. anyone who knows anything about electrical circuit boards knows that today they are all coated and the buttons are sealed to prevent sparks/shorts.
as for the running car myth... i think shutting off your car is a requirement in some states due to the fact that their inspection standards do not require you to upgrade your fuel delivery system, because the old system did not have fuel feedback prevention. instead of putting a sign that says "vehicles made before 1980 shut engine off" they put one saying "shut engine off". i leave mine running when it is cold outside so i can jump back inside... when it is warm or i am going inside the station i turn the car off. fueling your car with the engine running does not cause explosions, unless sufficient amount of fuel vapor builds up around your engine where things like alternator and compressors may create a large enough spark to ignite the vapor. there is nothing in your fuel tank that will cause the explosion. fuel goes through a lot of valves, a pump, a filter, and injectors in order for the spark to reach the fuel vapors created by .... fueling your car???? that makes no sense. and the whole idea about losing pressure in your fuel tank is retarded. if you examine your fuel cap, it is a basic valve so that air may enter the fuel tank. when you open it, you are doing your fuel tank a favor. think about basic fluid dynamics. fuel goes to the engine - space is emptied in the tank - something is needed to refill it. that is why when you unscrew it, air is always sucked in.
the only thing i am really worried about is the static electricity when you touch your car.. but when i open my door, i always touch the metal frame and all static electricity built up from the cloth interior and my sneakers on the carpet is gone.
just dont smoke and refuel, that is pathetic.
well put my friend! you sound like an engineer. except for the pcb coating/sealing. i was just thinking that electrical shorts (im not talking about switches) in a cell phones or any modern electronic device, are very rare! sparks from shorts are due to electrical failures, and even then i dont think its enough to ignite gasoline vapors, even if your phone was next to the pump handle! just my 2 cents
Old Mar 14, 2005 | 11:22 PM
  #42
MaximA VlaD's Avatar
Originally Posted by gto400no1
only thing i notice that is bad about leaving ur car on while fueling is that people sometimes forget that the car is still fueling and leave while its still pumping, lol.
Old Mar 15, 2005 | 03:52 AM
  #43
C MAX's Avatar
Originally Posted by eturnl
just my 2 cents
the thing is nobody wants to be that rare coincidence. it probably will never happen but it can.
Old Mar 15, 2005 | 04:31 AM
  #44
deezo's Avatar
http://www.townpump.com/CStore/FuelingSafety.htm
Old Mar 15, 2005 | 04:35 AM
  #45
Armelius's Avatar
There is no extra danger leaving the engine running other than you will be using more gas and wearing the engine down at idle. It used to be no one turned their cars off at the gas statiion. You would pull up someone would fill your tank and ask if you wanted your fluids checked and then you would turn off your engine.
Now when you go to say a Sams Club gas station you see a line of vehicles all with their car running in long lines until they get to the gas pump and then they shut off their car.
In North Dakota we left the cars running all the time except when we were sleeping or when we are going to be somewhere for long periods of time.
Old Mar 15, 2005 | 07:42 AM
  #46
Ninos_Maxima's Avatar
be the change u want2C
Ive seen some stupid teens rip out the fuel pump, The funniest I say was this guy I remember from high school a few years ago. worst thing for the guy is that he was trying to be "Gangster"
Old Mar 15, 2005 | 08:24 AM
  #47
Originally Posted by TickingVTC
this is on the 5th gen forum but they arent answering the questions...they are just getting into opinion.....IS IT A FACT THAT TAKING OFF THE GAS CAP WHILE THE ENGINE IS RUNNING WILL TRIP A SES CODE OR EVAP VENT CONTROL VALVE CODE?
i don't think any of us can answer your technical question. but if you ever need help with fires - you let us know
Old Mar 15, 2005 | 10:22 AM
  #48
sryth's Avatar
I have taken my gas cap off while my engine was running (bad starter) and it did not trip my CEL.
Old Mar 15, 2005 | 11:08 AM
  #49
maximaintheface's Avatar
i dont know why u cant just turn the key off. fuel up and turn it on take mabye 3 seconds more. if your really in that much of a hury get less gas.... or if its to hot its not like if you keep your doors closed its not gunna stay cool for a few minetes or if its cold either way
Old Mar 15, 2005 | 03:39 PM
  #50
sryth's Avatar
Well, I did it because I had a blown starter and I didn't feel like being that guy who has to pop-start his car in a gas station
Old Mar 15, 2005 | 03:45 PM
  #51
vortechpower's Avatar
Well I read in the owners manual that if you expect to leave the vehicle for more than 1 minute you should turn the motor off for better fuel economy. My dad has pulled the pump out 2 times! He has his mind on bigger things!
Old Mar 16, 2005 | 10:28 AM
  #52
Go DAD!! .
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Samedi
Aug 13, 2015 04:05 PM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
