about to buy this whole set... any info?
Old Mar 14, 2005 | 03:32 AM
renatonetmail
Iam about to buy this:
http://www.customenterprise.com/view.../vts/design004
since i got under my car for the first time and Y-pipe is broken and you heard a clank-clank on every little bump.
Any info on the easyness to install this whole set (DYI) ?
are the gainings the same than other y-pipes?
Thanks for the feedback,
I wanted to ask the ORG first before i shred $350
Old Mar 14, 2005 | 05:13 AM
deezo's Avatar
There are numerous threads about y-pipes, even in the stickies. Plus, why would you pay $350 when you can them them for under $200 from Warpspeed and Budget?
Old Mar 14, 2005 | 05:16 AM
renatonetmail
the 350 is for the set. I went to budgetexhaust.com and couldn't place an order. Is LSS same as Budget?
Old Mar 14, 2005 | 05:29 AM
PAREDLINE's Avatar
Is your factory Y pipe broken? Or an aftermarket. You might just need a flex pipe. A muffler shop can weld on a generic flex pipe for about 50 bucks.
If you have the factory Y pipe then the aftermarket might make sense.
Old Mar 14, 2005 | 05:35 AM
renatonetmail
Is the factory. And i was looking at the whole set (y-pipe - high flow cat - hardware kit for both). I don't know what to do.
Old Mar 14, 2005 | 05:45 AM
PAREDLINE's Avatar
If you have the cash it seems like a good combo. Before you order just make sure that they have holes drilled out for your 02 sensors.
As for the install, the hardest part will be removing all your old stuff. If you dont have access to a torch you might need to get one of those air powered cutting tools.
If you're getting a Y pipe and a cat, maybe it would be wise to go ahead and do the rest of the exhaust too. It will save you some headache if you cant get the cat bolts apart which always happens. You'll just take off the front pipe nuts from the headers and take the entire exhaust out as one unit.
Old Mar 14, 2005 | 05:53 AM
renatonetmail
Its a shame I look around and no one seem to have any experience with this just released new y-pipe from custommaxima nor the whole set.
Old Mar 14, 2005 | 07:13 AM
nismos14's Avatar
§è~® f®ÈÄk
just get it most y's are the same, spend the money get it, and be happy
Old Mar 14, 2005 | 07:17 AM
rsly33's Avatar
http://www.vqpower.com/v2/article124.html
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
atriuum
Sep 28, 2015 01:19 PM
pears
Sep 18, 2015 05:25 AM
flu2000
Sep 14, 2015 12:34 PM
