Programming key fob remote
Old Mar 14, 2005 | 05:31 PM
mix master's Avatar
I didn't see anything on the site about this (for some reason I can't use the search feature), but I'd like to find some information about how to program a new OEM key fob remote to work on my 95 SE. Thanks for your help
Old Mar 14, 2005 | 05:35 PM
Turk's Avatar
1.Get in the car lock all the doors.
2.Stick the key in and out 5-6 times in 8 seconds or so. (don't turn the key in and out only)
3. Your hazard lights should flash 2 times.
4. Turn to ACC. and push the lock button it should flash and wala.
Old Mar 14, 2005 | 05:36 PM
MAXRB8's Avatar
Here you go:
http://www.jatan.net/tsbs/044567.pdf
Old Mar 14, 2005 | 05:54 PM
mix master's Avatar
Thank you very much!
Old Mar 14, 2005 | 06:38 PM
2 Da Max's Avatar
i did with my keyfob and it still doesnt work! i changed the batt and everything. i mean i got the hazards working but after i turn to acc and press the lock button no hazards flash
Old Mar 14, 2005 | 07:58 PM
Bender-san's Avatar
Have fun with this one. It's easier said than done the first few times you try it.
Old Mar 14, 2005 | 08:16 PM
Turk's Avatar
I had the same problem. I figured it out by doing all the steps and on you door panel to lock and unlock all the doors, you unlock and lock door and click on thhe remote. It should work.
Old Mar 16, 2005 | 04:39 PM
mix master's Avatar
It worked great for me. I was able to program 2 remotes to work although it was a little tricky at first getting the second one programmed. After the first remote, you've got to keep the key in the ACC position while locking and unlocking the door manually, then hit the grey lock button on the second remote and that was all it took.
Fbana41
Aug 29, 2016 12:18 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
flu2000
Sep 14, 2015 12:34 PM
