Springs And Shokcs Combo
Old May 5, 2001 | 09:02 AM
megamax96gle
im intrested in lowering my car and also getting some shocks .... whats rae the options, prices and **** like that whats all your opoinons on the best ones... i am located in south jersey so any1 know fo a good install place....
Old May 5, 2001 | 09:09 AM
Gotrice4's Avatar
You have a few choices on springs
Eibach
H&R
Progress
Suspension Techniques
Intrax
Sprint
Apex
and so on depends on what ride, drop, and performance you want
Shock/struts you have
Tokico
KYB
Koni(but the front struts are not a direct bolt on)
Consensous on this board is Koni's are the best option with lowered springs
fnkmaster's Avatar
I think eibachs and konis are the best combo... moreover you do have to option of adjusting the stiffness of the shocks with the konis. As for prices, you might want to check out shox.com or the group buy pages here on maxima.org
Old May 5, 2001 | 01:52 PM
ybelm620
I say get the Koni shocks and struts. As for springs it depends. The Eibach Pro-Kit is stiff but the car from what i have seen looks still stock height, same thing with the H&R they drop the car but not low enough. I myself will either go with the Intrax or Sprint springs because they give the Maxima a more aggrasive drop. So for the springs it depends on how low of a drop you want, but for the shock/struts if you have the money to spend get the koni's, tokico's are also good choice to.
Old May 5, 2001 | 02:39 PM
AndyXXL's Avatar
H&R and Koni
Look at my sig pic.
www.shox.com has good prices on almost every suspension part.
Old May 5, 2001 | 04:32 PM
NickStam's Avatar
Re: H&R and Koni
Here are some picture of maximas with suspension. They aren't all Maximas, but there are about 4 Maximas:
http://www.performanceix.com/gallery...suspension.asp
Old May 5, 2001 | 05:04 PM
kit's Avatar
kit
I got H&R springs
I got H&R springs on my 99 max, but with stock shocks...
i won't suggest u to get H&R though... it's sure that they r cheap, and lower and stiffer than the stock ones, but not stiff enough...
ST has the best lowering ratio... and it's stiff enough...
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
