wheel spacers?
Old Mar 16, 2005 | 06:02 PM
ruffrida24444
wheel spacers?
anyone have wheel spacers for the rear wheels to "untuck" the wheels and even it out? if so whered u get em, how much were they and how many Millimeters?? thanks
Old Mar 16, 2005 | 06:31 PM
p00tan6's Avatar
I would like to know this also. Do wheels spacers cause uneven tire wear for those who have used them?
Old Mar 16, 2005 | 06:37 PM
Magikone69's Avatar
i three would like to know, i have the 2k1 se 17's and they are so tucked in the rear it looks bad. i want to atleast have them stick out to the edge of the fender.
right now everyone is sayin H&R, but im jus tryin to get a good size, i wish i can test em on before i buy.
Old Mar 16, 2005 | 07:30 PM
nismo2ner's Avatar
down with Bing
i would like to know this too for the same reason looks very funny with the back tucked in and the front sticking out with my 18s ....
Old Mar 16, 2005 | 08:35 PM
eturnl
Me Four! Where's Everyone At?!
Old Mar 17, 2005 | 01:44 AM
Supermax95's Avatar
I have wheel spacers on my rears becuase the rims i put on wouldnt fit over the center dust cap thingy, anyway....they are either 10mm or 7mm and i also put in longer wheel studs to be safe.....looks fine doesnt stick out at all but lines up well.
Old Mar 17, 2005 | 05:43 AM
kingrukus's Avatar
no more maxima...
I had the same problem, so I ended up removing the center dust cap and using a very thin 3mm spacer to clear.
Old Mar 17, 2005 | 07:04 AM
ruffrida24444
thanks guys how much did they run you? and where did u get em? anoyone else???
Old Mar 17, 2005 | 07:07 AM
azmaxipad's Avatar
i work for a local tire shop and we discourage the use of spacers. Unless you do extended studs. This do to the fact that spacers with a stock stud does not allow the lug nut to grip enough threads. In turn leading to potential wheel falling off. So if you have to use spacers do it right
Old Mar 17, 2005 | 09:03 AM
kingrukus's Avatar
no more maxima...
I got them from a local performance shop for about 25 dollars. My tire shop which installed my wheels discouraged the use of anything bigger than 3mm because the studs will definitely not be long enough and can pose a serious hazard.
Old Mar 17, 2005 | 10:11 AM
VQuick's Avatar
Chassis Freak
H&R are what you want, 15mm or 20mm for the rear. Only problem is H&R spacers have been nationally backordered since October or even earlier.... I'm still waiting for mine. H&Rs are hubcentric and include longer studs so you really don't have to worry about anything. They may make your wheel bearings go out faster due to pushing the wheels out and giving them more leverage. Otherwise there are no cons that I know of, just the pros of MUCH better looks and theoretically better handling (wider track). I wouldn't do spacers on the front becuase with a +35 or 40 offset wheel they're already perfect.
Old Mar 17, 2005 | 10:55 AM
BEJAY1's Avatar
Conecarver
Eibach?
Has anybody considered Eibach's wheel spacers instead of H&R because of the backorder? They offer 5mm - 25mm both with longer bolts and w/o.
Old Mar 17, 2005 | 11:34 AM
Xmax's Avatar
I have wheel spacers to, but they are ghettofied, and don't ask me how i did it, cuz i don't want to be liable for any screwups or if it causes any accidents. So far I had them for more than 2 years so far no problems. If I have time ill try to post a pic of it.
Old Mar 17, 2005 | 11:57 AM
PAREDLINE's Avatar
I got mine at Poop... I mean pep boys. Off the shelf. I think they were 5.99 each. I dont know how many millimeters they are but they work fantastic.
It's very very difficult for a wheel spacer to "fail" because all it is is a friggin piece of aluminum with holes in it.
I used the OE bolts and some aftermarket low profile lug nuts that I needed for my wheels.
It's not a big deal. You dont need brand name spacers. Wheel alignment and balance is fine too. Just when you put them on make sure they are centered around the hub equally.
Old Mar 17, 2005 | 12:25 PM
jwmaxse's Avatar
The only thing that I can see failing is if they were to crack or shift. If this happens the lug nuts will become loose and your tire could fall off.
I ordered 15mm H&R spacers for my 3rd gen a while back and the studs didn't fit into the hub because of the "girdle" I guess you could call it was too big. They were $140 shipped and I never even used them, I'm not sure if they would fit onto my 4th gen though, maybe they'll fit on my Z.
Old Mar 17, 2005 | 01:27 PM
kingrukus's Avatar
no more maxima...
Nope. Any good vendors to purchase from? I was looking foward to Shadow producing wheel spacer with studs a while ago...but I guess that fell through? I would like to slap on some 20 mm spacers in the rear.
Old Mar 18, 2005 | 05:58 AM
BEJAY1's Avatar
Conecarver
Google search showed a couple decent websites that looked ok. Summit was the only one I've used personally.
Old Mar 18, 2005 | 09:54 AM
VQuick's Avatar
Chassis Freak
LOL, apparently the only brand of wheel spacers that Summit carries is "Mr. Gasket" brand....hahahahhaahahaahhah!
http://store.summitracing.com/defaul...=egnsearch.asp
Old Mar 18, 2005 | 10:14 AM
BEJAY1's Avatar
Conecarver
Dig a little deeper. Go to their site and type "Eibach spacer"
Old Mar 18, 2005 | 04:12 PM
ruffrida24444
i shoulda searched more about the offset b4 i got my rims
Old Mar 18, 2005 | 08:53 PM
VQuick's Avatar
Chassis Freak
Eibach only makes 5mm spacers for the Maxima. Source: Eibach's website
Old Mar 19, 2005 | 04:41 AM
BEJAY1's Avatar
Conecarver
You're right. Sorry everyone. I tried a couple other 5lug vehicles like ours and no other matches either.
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
