LSD & ABS - How do I tell if I have them?
Old Mar 18, 2005 | 09:29 AM
kartiste's Avatar
Is there a way to tell from the nuber plate if I have ABS and a limited slip differential or not?
thnx
Old Mar 18, 2005 | 09:32 AM
MaximaSE96's Avatar
Maxima Owner
well if ur car is canadian u might have LSD but i doubt u do..USDM models didnt come with LSD.......ABS there is a huge accuator right near ur master cylinder.....but if that dont help http://courtesyparts.com/specs/vin.html
Old Mar 18, 2005 | 10:46 AM
kartiste's Avatar
That page doesn't address the trans and axle codes. Is there another page that does? BTW, the car is a 99 SE-L, VIN JN1CA21D6XTxxxxxx. The trans code is RS5 F50A, and the axle code below it is FG38. Does this tell?
Old Mar 18, 2005 | 10:51 AM
mattC's Avatar
Easy way to find out if you have ABS. Next time it rains, slam your brakes hard somewhere. If your pedal starts vibrating and you are able to hold the car straight, you have ABS, if you lose control and hit a tree or pole, you don't have abs.
Old Mar 18, 2005 | 10:58 AM
I answered the ABS question 3 days ago.... It's on page 4 in this forum you lazy sob. j/k
Here you go.
http://forums.maxima.org/showthread.php?t=388251
Not sure about the LSD. I'll get back to to you on that one....
Old Mar 18, 2005 | 11:01 AM
Bobo's Avatar
I have a 95SE, 5-speed. Its a Canadian car. Its loaded and has ABS. Would it automatically have the LSD then? If so, are the Canadian LSD 5-speeds less prone to the dreaded differential bearing problem?
Old Mar 18, 2005 | 12:03 PM
DR-Max's Avatar
You don't have to wait til it rains. Just find a safe road somewhere away from heavy traffic and do it there. Slam on your brakes and if they pulse (up and down), then you got ABS. That's how mine works on my truck.
Old Mar 18, 2005 | 12:13 PM
C MAX's Avatar
if your vin has a V in it then you have it
Old Mar 18, 2005 | 12:43 PM
Bobo's Avatar
I checked and have no V. It seems to me the other letter was an A which I have. I take it that not all 95SEs for the Canadian market had LSD. I ordered mine loaded and I don't remember it being specified as an option. Maybe it came with the 96s.
Old Mar 18, 2005 | 04:13 PM
ptatohed's Avatar
Licensed to Spell
:o)
What does a 'V' have to do with anything? A 'V' means it would be a '97.
Keep in mind, the VIN does not always tell you that you have ABS. For instance, I have an 'A' for 'Miscellaneous (probably because I have side airbags) but I have ABS. I beleive The Wizard has a 'D' and he has ABS. The easiest thing to do is what The Wizard said, simply turn your key to the 'on' position and look for the ABS light.
Old Mar 18, 2005 | 07:21 PM
mattC's Avatar
Yeah and if for some reason he didnt have abs, he would flat spot his tires causing a ride nobody would want to live with
Old Mar 19, 2005 | 05:42 AM
C MAX's Avatar
i never said the V was for abs read more carefully, i said for LSD.
Old Mar 19, 2005 | 08:50 AM
Wetballoon's Avatar
I don't have ABS, but don't they put an indicator on the dash that lights up when you start the car? My truck has one. It says "ABS". But yes, if you can get it to slide sideways while breaking, either you don't have ABS or it doesn't work.
Old Mar 19, 2005 | 09:36 AM
sunten1
TO find ABS
Put Key in ignition
Turn car on
Look at guages you should see an abs light some where
if you don't you don't have abs
Old Mar 19, 2005 | 10:28 AM
DR-Max's Avatar
Its not hard to get abs to kick in. You don't have to be going so fast to get it to activate. If your gonna worry about that, don't race and save your tranny or engine.
Old Mar 19, 2005 | 10:38 AM
mm347's Avatar
Not true, SE-L's with auto trannies did have LSD.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
leatherneck
Sep 30, 2015 09:16 PM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
