Grounding Points
Old Mar 20, 2005 | 08:35 PM
Ninos_Maxima's Avatar
be the change u want2C
Grounding Points
Who knows where all the grounding points are in our car? Im gonna replace all the grounds. I heard it helps throttle response and a whole bunch of other things, . Also 4 Gauge wiring will be the most efficent or am I wrong?
Old Mar 21, 2005 | 02:23 AM
bhmax16's Avatar
This may help you out a little http://www.vqpower.com/v2/modules.ph...howpage&pid=68
Old Mar 21, 2005 | 06:35 AM
DAVE Sz's Avatar
Hooooooonda.....
There's over 120 ground points, how in the world would you replace them? Replacing means to take the old out and put the new in, meaning you'd have to trace each ground back to the source, cut the wire, and splice in a new one. There's like 5-7 ground points you should clean and run new wires to from the battery or something. 4ga is overkill.
Old Mar 24, 2005 | 08:55 AM
Thanx BhMax. But Dave, All my ricer friends are telling me I should use 4ga wire
Old Mar 24, 2005 | 08:57 AM
dgeesaman's Avatar
Maintenance Monster
That's why they're ricers.
Inexpensive car audio amp wire is plenty for any grounding you do. You can add the heavy ground cable after cleaning the existing one - taking out the existing is a bad idea, IMO.
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
