Sneek a peek at my weekend project.
Old Mar 22, 2005 | 05:02 PM
Dubbya's Avatar
VK56 Inside
Sneek a peek at my weekend project. **UPDATED**
Here is whats coming up for this weekend. Sorry for the crap pictures, I will use a better camera during the install and update with new pix. Check out page 3 of my cardomain. I also added page 2. Its the aftermath of a fender bender I had not too long ago.
Edit
New and better pics are up!
http://www.cardomain.com/memberpage/772559/4
Old Mar 22, 2005 | 05:43 PM
RA030726's Avatar
I'm nutty for Nissans
yum ATE super blue
with such nice stuff I am amaized that you didn't get performance pads.
Old Mar 22, 2005 | 06:09 PM
Mr.Duck's Avatar
where did you get the apexi ws!?!??! unless you got it before they discontinued it.. lucky SOB good luck with the project!
Old Mar 22, 2005 | 06:10 PM
Dubbya's Avatar
VK56 Inside
After you see the before pictures it will explain every thing. Axxis Ultimates ate my rotors. BIG TIME. I have only had my current set up for a year, its trashed.
Old Mar 22, 2005 | 06:12 PM
Dubbya's Avatar
VK56 Inside
I got the WS from Flavor24/7 (thanks again, I love it). I know of another that may still be for sale. Just let me know if you want me to point the direction.
Old Mar 29, 2005 | 07:48 AM
Dubbya's Avatar
VK56 Inside
Bump for the edit.
Old Mar 29, 2005 | 09:55 AM
Flava_24/7's Avatar
Boosted Panda
D@mn, looks like your did take a beating from that hail storm. Sorry.
I hope all works out for ya!
BTW, nice brake setup.
Old Mar 29, 2005 | 10:01 AM
MaDMvD's Avatar
Nice. I am actually expecting my pads/rotors any minute now. I went with the slotted/dimpled Bremobos and Axxis Ultimates. This is going to be my first time doing brakes, so let's see what happens.
Old Mar 29, 2005 | 11:25 AM
Dubbya's Avatar
VK56 Inside
Thanks Ralf! I think it looks a lot cleaner with the painted calipers.
Old Mar 29, 2005 | 11:26 AM
Dubbya's Avatar
VK56 Inside
Good luck with the Axxis Ultimates. Thats what I had on my car before and they ate my rotors. Just make sure to keep an eye on the rotor wear and pad life.
Old Mar 29, 2005 | 11:32 AM
lilaclucymaxima's Avatar
Team Ramrod
cool brakes... i wouldnt even wanna ruin them if that was me
Old Mar 29, 2005 | 06:52 PM
HomerMAC's Avatar
Donating i30 Owner
hey u cant cut the rotors with a regular machine if the pad is sloted and drilled...?
Old Mar 29, 2005 | 07:19 PM
ny96max's Avatar
i bet you can stop on a dime with that setup.
goodluck with it!
Ant
Old Mar 30, 2005 | 07:41 AM
Dubbya's Avatar
VK56 Inside
I am not sure if I can or not. One of the guys I work out with at the gym works at Meineke (sp?) and claims they can do it. Will have to find out one of these days. Most other people I have talked to say that it cannot be done. As for the stopping power, its pretty good. The pads dont bite as much as the Axxis Ultimates, but then again I dont want to chew up my rotors either.
Old Mar 30, 2005 | 09:29 AM
jblinga's Avatar
Rotors look good but consider the 300zx calipers!
Old Mar 30, 2005 | 09:32 AM
Dubbya's Avatar
VK56 Inside
Yes, I will consider them. I just have other things lined up for mods that I need to pay for and get done 1st. I still have to get my I30 Trunk Lip painted, Motostrom UPD needs to be bought, new tires, and get a new rear bumper cover. Will I be able to keep my same pads and rotors with the caliper swap? I honestly havent done much research on that yet.
Old Mar 31, 2005 | 09:20 AM
konak85's Avatar
Dumb question, but what causes that rusty stuff to go all over your brakes? I don't think its brake dust. I got it all over my brakes after i installed new rotors and pads.
Its hard to take off. How can you prevent it?
Old Mar 31, 2005 | 09:27 AM
Larrio's Avatar
The Definitive AE Master
Looks good with all those shiny new parts! BTW, your rotors are backwards, slots should face forward and up. Don't waste your time on the 300ZX calipers, not a worthwhile thing to do on stock size rotors.
Old Mar 31, 2005 | 09:47 AM
2 Da Max's Avatar
dam nice rotors
Old Mar 31, 2005 | 10:21 AM
Flava_24/7's Avatar
Boosted Panda
The way the slots go depends on the the way the vanes are inside the rotor.
If the vanes are straight out, no angle, then it doesnt matter which way the slots go.
http://www.reddotracing.co.uk/eng/Te...20Talk.html#31
Im not sure which Dubbya has, he may need to look into that.
Old Mar 31, 2005 | 10:52 AM
Larrio's Avatar
Correct. But I haven't seen curved vane rotors in stock sizes for maximas. They're straight so that they only need to make one rotor, and it fits both sides.
Old Mar 31, 2005 | 11:02 AM
Dubbya's Avatar
VK56 Inside
The 1st set of rotors I had came with a sheet that expained the set up like this:
My current config is best for light braking applications. The rotors will cause less bite on the pads
The opposite config is best for hard braking applications. The rotors will have a greater bite on the pads.
I feel that I do not need the greater bite at the cost of my pads, so I went with the 1st. Plus I think they look weird with the slots going in the other direction.
Old Mar 31, 2005 | 11:05 AM
Dubbya's Avatar
VK56 Inside
That rust is just that. When your rotors get wet, they will rust. Unless you buy painted or zinc plated rotors there is no good way to prevent the rust from coming back. I suppose you could take them off and sand down the rust on the rotors, mask off the areas that the pads will contact, and paint the rest. Lots of trouble though. I would wait until you need new rotors and buy ZINC plated. The painted ones are ok, but I have heard the paint will not last as long as the zinc plating.
Old Mar 31, 2005 | 11:06 AM
Dubbya's Avatar
VK56 Inside
The veins are straight, so the rotors are interchangeable from side to side.
Old Mar 31, 2005 | 11:08 AM
Dubbya's Avatar
VK56 Inside
Again thanks for all the compliments guys. I worked hard to make it look nice.
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
maximusrising
Sep 2, 2015 09:55 AM
