Steering wheel doesn't center sometimes after a turn
Old Mar 25, 2005 | 12:32 AM
RapidMax's Avatar
I just put my summer wheels on and had them balanced. I've noticed since then that the steering wheel sometimes doesn't center correctly after making both a left or a right turn. Also it turns right or left a little if I'm going straight and hit a bump and kind of sticks there. I just had an alignment about 2 months ago also and the tire pressure is fine.
Old Mar 25, 2005 | 04:12 AM
joeeey's Avatar
From what you state it sounds like your steering rack is binding up. You might need to replace the steering rack.
Old Mar 25, 2005 | 06:43 AM
njmaxseltd's Avatar
Loose suspension components.
Check the tie rod ends, both inner and outter.
Check the upper strut mounts.
Check the lower ball joint
Check the lower control arm bushings.
trasmadean
Feb 1, 2017 08:20 PM
vingodine
45
May 21, 2016 12:46 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
jhontelj
Aug 17, 2015 04:07 AM
Flores94
Aug 13, 2015 01:17 PM
