door pannel question: Where are the screws at? need help asap
Old Mar 27, 2005 | 03:48 PM
PTownMax's Avatar
I still miss the max
i know there's one in the door handle, where are the rest? i'm sitting in my garage trying to get them off right now
Old Mar 27, 2005 | 03:56 PM
jackiss2888's Avatar
depending on which doors, the inside door handle and the two on the bottom of the door sills.
Old Mar 27, 2005 | 04:26 PM
PTownMax's Avatar
front l & r and thanks appreciate it
Old Mar 27, 2005 | 04:57 PM
sunten1
its in the audio forum, its a sticky
Old Mar 27, 2005 | 05:02 PM
Black Maxima
You have to unclip the plastic around the door handle, screw in the cup, two at the bottom of the door, step light, window controls.
Old Mar 28, 2005 | 10:51 AM
FormorAccordMan's Avatar
You dont need to pull the window controls out, you just need to disconnect the harness behind the door. Door latch trimming---->screw in the pull pocket------>two screws at the bottom of the door under the storage pocket------->pop out the courtesy lights and disconenct the harness--------> Carefuly pry the door panel off and lift straight up (be careful of the sail panel). Your door panel is now off
Old Mar 28, 2005 | 11:51 AM
Black Maxima
For me, I found it easier to disconnect the window controls before taking the door panel off.
Old Mar 28, 2005 | 12:39 PM
newdiamond's Avatar
i found the secret to easily removing the door panel is once you have it loose around the bottom lay underneath and lookup at the bottom of door latch 'cup' you will see a small black clip holding it on, use a long handled straight screwdriver to reach up and put the clip off, this will make it MUCH eaiser
Old Mar 28, 2005 | 12:43 PM
Black Maxima
I just rip it off after I unscrew/bolt everything. It's only plastic clips.
REDinLV
Aug 15, 2024 12:30 AM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
sliptap
Sep 30, 2015 05:57 AM
