Noises from passenger side wheel.
Old Mar 27, 2005 | 04:58 PM
SMX95's Avatar
I get this rubbing sound like if the wheel is rubbing against plastic or if something is draging. When I make side to side turns I can hear it. Just sounds like my wheel is about to fall off. When I come to a complete stop sounds like my control arm bushings are just shot and make a low pitch noise just sounding like everything is about to break off. I checked my cv boot, its fine, I think something is bent, or my wheel bearing is totally toasted. Can someone give me some info here. I dont know how im going to take my car to school now. I dont feel safe traveling such a long distance and back.
Old Mar 27, 2005 | 05:25 PM
SMX95's Avatar
When i hit the brakes to come to a complete stop a bit hard i hear just this noise like the same noise you hear when you turn your wheel and you hear your powersteering making a click noise and your engine rpm goes up a bit and with the wheel noise happens when im doing 10mph or less, make turns from side to side and going slow, makes a rubbing against somthing noise or im draggin something, its not a constant noise its more of a grind grind silence then grind grind then silence.
Old Mar 27, 2005 | 06:14 PM
SMX95's Avatar
bump.. anyone...
Old Mar 27, 2005 | 07:48 PM
nitromax's Avatar
sounds like strut bearings gone bad. jack the car up, grab the wheel and slowly turn it. if you can feel a gritty vibration thru the wheel, most likely it's caused by bad strut bearings. if you have a friend with you, have him to feel the spring while you turn the wheel, vibration = bearings. while it's up rock the wheel from top to bottom slightly, looking for looseness in wheel bearings. there should be no play in the wheel bearing.
Old Mar 27, 2005 | 11:31 PM
larryseibel's Avatar
sounds like either brakes or a wheel bearing. thats the noise my wheel bearing made when it went.
Old Mar 28, 2005 | 06:17 AM
SMX95's Avatar
It doesnt happen when I turn the wheel side to side while not moving only at low speeds. Im guessing its the wheel bearing. My steering wheel is still centered, guessing if I had a bent control arm I would feel/see a difference on the road and the position of my steering wheel. Brakes Still have life on them but need replacing sometime around 2-3 months.
Old Mar 28, 2005 | 10:01 AM
Silverbullitt's Avatar
I have the same problem except mine sounds like somethings bumping against the inner fender well. Guess its the bearing
The Wizard
24
Oct 1, 2015 08:47 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
