Most newb question: trunk lock
Old Mar 27, 2005 | 07:07 PM
nosispower's Avatar
Before I go to the stealership or a locksmith to fix this...is there a reason my trunk won't open with a key, but will open from the switch inside?
The key goes in smoothly, but doesn't turn at all. It was fine before and then it just stopped working.
Old Mar 27, 2005 | 07:13 PM
joeeey's Avatar
Just remove the clip that holds on the cylinder and bring it to a locksmith. It's gonna be alot cheaper than the stealership.
Old Mar 27, 2005 | 07:14 PM
bullfrog's Avatar
I gotta do the same thing sometime soon. Mine has always been like that. Then again, it is good motivation for me to just get a rearview camera and stick it in that hole.
Old Mar 27, 2005 | 07:18 PM
Kevin's Avatar
i push the slot in with a small screwdriver and shot some wd-40 in there. within minutes it worked just fine. did this for both doors too.
Old Mar 27, 2005 | 07:27 PM
mrgreek's Avatar
mine is like that too for some reason, but i have no intention in fixing it...i got the thing inside...and the keyless entry with it...
i would go with kevin though...hes lived it, nothing bad can happen as a result either...id assume
Old Mar 27, 2005 | 07:33 PM
Crockpot's Avatar
previous owner never used the keyhole for the trunk.. i sprayed wd-40 in it and works fine now
Old Mar 27, 2005 | 08:05 PM
maximaSE327's Avatar
i always relied on the keyless or inside as well... only prob is, when i was in an accident and the battery was smashed, none of those handy electrical things worked... and i had stuff in the trunk i needed to get out... so i learned my lesson... better to be able to use the key just incase
Old Mar 27, 2005 | 08:22 PM
mrgreek's Avatar
true, gl with the wd40 idea, respond back here if it works, id like to know...
if that happens to me, ill hire my buddy to crawl through the poutch opening thingy in the back seat
Old Mar 27, 2005 | 08:56 PM
nosispower's Avatar
I'll try it tommorow afterschool. I don't have a keyless entry, so everytime I need to open the trunk, I need to open the door to pop it. Kinda makes me miss my dad's minivan tailgate...
Old Mar 27, 2005 | 11:29 PM
RicoSuave98's Avatar
ive never even tried my key for opening the trunk- guess i ought to now
Old Mar 28, 2005 | 05:18 AM
passEMonTHErite's Avatar
Its possible, if you bought the car used, that they only gave you the "valet key".
Old Mar 28, 2005 | 07:41 PM
nosispower's Avatar
Nuts....sprayed WD-40 into the lock and still nothing. The key goes in fine, but it doesn't turn AT ALL. It feels like it's the wrong key.
The key worked fine before, but my dad went to get a spare key made and I guess he tried opening the trunk with it and maybe broke something? THe spare key never worked (in any of the locks) and now my real key doesn't work either.
REDinLV
Aug 15, 2024 12:30 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
Hailstatejig
Sep 2, 2015 06:52 AM
