HOWTO: new twist on dome light LED
Old Mar 27, 2005 | 07:13 PM
bullfrog's Avatar
I wanted to do my dome light, but I didn't want to lose the normal white light to use when I wanted it. I just wanted it to light up blue like my doors when I opened them and stuff, and then still be able to use the white light in the dome without the blue for stuff when I wanted. Here's how I did it:
I used a 13/64" drill bit to make my holes for the 5mm LEDs and it worked perfect, just for reference. I followed wariow's instructions for the whole thing except for the following changes:
1) Desolder the ground wire that runs from the plug to the switch from the switch. Its the one closest to the end of the switch by itself:
2) Attach your LED negative wires to that ground wire, and follow Wariow's instructions for the rest:
Hope this helps anyone looking to do the same thing. Have fun with it!
Old Mar 27, 2005 | 07:18 PM
Chickan's Avatar
awesome, sounds like its worth the effort. Any pictures of the finished product?
Old Mar 27, 2005 | 07:25 PM
bullfrog's Avatar
just went outside and snapped a few finished pictures:
this was with 10 blue LEDs by the way...
inside the car:
from outside the car with the doors closed:
from outside the car with the door opened:
Old Mar 27, 2005 | 08:00 PM
Tyrexx's Avatar
Nice job.
Old Mar 27, 2005 | 08:01 PM
nitromax's Avatar
i hope you meant 3/16" drill bit. nice look!!
Old Mar 27, 2005 | 08:19 PM
bullfrog's Avatar
13/64" actually. I changed it. Thanks.
Old Mar 27, 2005 | 08:30 PM
Flava_24/7's Avatar
Boosted Panda
Looks good.
You could have used one of these bulbs with the leds inside of it already...
The pictures do not do it justice. It actually glows quite bright.
Its definately noticable from outside.
Old Mar 27, 2005 | 09:12 PM
Nick7455's Avatar
Can't wait till this summer...imma mod the **** outta my car....more so then now. So many little things...
Looks good!!
Old Mar 27, 2005 | 11:49 PM
dawalkster's Avatar
is craving Bojangles
i cant wait till i finish wiring up my dome light; i managed to get 17 leds in that thing. i figured i might as well not waste any of the 50 leds that i got so i stuffed as many as i could in the dome light. also i heard that if you sand down the tips of the leds then it will disperse the light better- what grit sand paper would you use for that?
your dome looks good by the way
Old Mar 28, 2005 | 02:49 PM
maxiquin's Avatar
Originally Posted by FLAVOR_24/7
Looks good.
whats the numbers on those bulbs???? i wanna get some!
Old Mar 28, 2005 | 03:47 PM
MAXRB8's Avatar
Are these them?
http://cgi.ebay.com/ws/eBayISAPI.dll...763024884&rd=1
Are these the correct size, my link to my Maxima bulb chart has died!
Old Mar 28, 2005 | 03:58 PM
99SEL4ME's Avatar
You have waaaaaaaaaaaaaaaaaay too much time on your hands. j/k I'm just jealous. Good work mang.
Old Mar 28, 2005 | 04:15 PM
Flava_24/7's Avatar
Boosted Panda
Here.....
http://www.superbrightleds.com/specs/festoon.htm
MaxLife17
Jun 27, 2019 01:37 PM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
