newb question about knock sensor
alright i thnik i got a bad knock sensor but i dont wanna check for the code on my ecu i read the stickies on how to tell if u have a bad knock sensor and they are pretty much the same problems i am having. well question one should i just change out the knock sensor or should i be sure and just check out the computer? also is there anyone on the org in miami florida? thanks
I have a dumb question ... how do you know your knock sensor is bad if your car won't throw a CEL and you don't have a OBDII scanner. I don't feel like paying some tire place $60 to check my ECU just to learn that nothing was wrong.
Stickies above will tell you how to use the self-diagnosis mode on the ECU. The code is 0304 in that mode. The knock sensor doesn't throw a CEL light because the knock sensor doesn't serve as an emissions function.
Originally Posted by NmexMAX
No that't not normal. Yes, you get bad gas mileage and poor performance.
Thanks for the quick reply, you think its worth buying on my own and then having someone install, or just have nissan do it?
quick question got a 98 gxe61,000 miles do i have to change out my knock sensor i have the code reader but nuthing comes up says no codes and wheres a good place to get it from and any have apic of where exactly its located and maybe the write up for it to
sdotcarter
Sep 2, 2015 09:53 PM
