bearing in before spring or after [trans]
Old Apr 1, 2005 | 12:58 PM
dayglo's Avatar
hi, i accidentaly took the wrong bolt out to drain my trani fluid a week ago and as the oil poured out it also drained out a 1' spring and apperently a small bearing[havent seen the bearing yet]. if the bearing did come, then ill be able to find it in the oil. I know ive seen somebody else here that did the same exact thing as i did and a spring and single bearing came out. Did you just put it back in there?
i worry because i wont want to just shove the bearing in and then the spring, and have a bearing doing something bad in my transmission like jumping around. im guessing i put the bearing in first and then spring right?
Anybody know what to do?
"That is the detent (detant sp?) spring. There should have been a small meal ball that came out with the spring. It is the mechanism that keeps the shifter in gear"
Old Apr 1, 2005 | 01:06 PM
dgeesaman's Avatar
Maintenance Monster
Hopefully you only removed one of the detente ball/springs from the tranny case. The ball goes in first, then the spring, finally the bolt.
See page MT-13, top illustration.
http://www.davidgeesaman.com/maxima/MT.pdf
Dave
Old Apr 1, 2005 | 01:14 PM
dayglo's Avatar
yeah it was only the one bolt i took out, ever since it c ame out ive had a TON of slack in 1st and 2nd gear and a bit in 3rd, but only 1 and 2 actualy fall out of gear.
i cant find anything specific in this pdf it would take forever..
i guess ill just put it all back where it came from
thanks for the help
Old Apr 1, 2005 | 02:24 PM
dgeesaman's Avatar
Maintenance Monster
Well it is the 1-2 shift rod detente, so when you put it back in, 1-2 should not be sloppy. It makes complete sense. You should be able to find it in the picture on the top of MT-13.
The 3rd gear thing is probably unrelated.
Dave
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
ef9
Oct 4, 2015 08:43 AM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
