Failed CT Emmissions NOx level bad??
Old Apr 1, 2005 | 05:37 PM
greenmax95se's Avatar
Help! Failed CT Emmissions NOx level bad??
Went to emmission in ct and failed due to NOx levels in exhuast i assume being bad. The guy told me to check my EGR system. I was at one point getting a code for the 3-way canister. is it hard to replace? should i change most the parts of the EGR system since im there going to take it apart? also how much do these parts cost, canister, and what ever else in tha egr system? replacement easy? any advice is great, i have about 15 days left to retest if not i dunno what happens cant drive car on street til fixed or whatever.
and if this helps, i changed all 3 my 02 sensors and brand new CAT. did it right before emmissions.. ECU light came up for all 3 02 sensors. if this info helpful on finding out my problem. any replies would help. thansk orger's.
-rafal
Old Apr 1, 2005 | 05:41 PM
oh and btw, my Nox level was at around 12XX and was suppose to be somewheres under 11XX
-rafal
Old Apr 1, 2005 | 07:45 PM
bump.............
Old Apr 1, 2005 | 08:00 PM
PAREDLINE's Avatar
They should have tested it again right then and there
Old Apr 2, 2005 | 06:02 AM
could be cause the car was running a bit funny just for that time? or because i get those CEL codes on and off?
-rafal
Old Apr 2, 2005 | 06:18 AM
Sky_99's Avatar
Had the car been properly warmed up? The shop that I worked at did emissions and you'd be suprised at how much of a difference a good 10-15min ride would make.
Old Apr 2, 2005 | 09:23 AM
Black Maxima
I'm afraid to go in for Emmisions. I haven't got the letter yet...
Old Apr 3, 2005 | 05:14 AM
the car was properly warmed up, but then again by the time they got to it, it was about 30 minutes in that time was still cold as **** outside and definetly dropped the temperature a bit. but im sometimes get that egr CEL. i dunno its on an doff. i've been trying to scanned all day yesterdaya nd i never get it. im still getting 2 02 sensor readings....... but i think i might have found a vaccum hose mixed up when i did my motor swap.
but when i changed the vaccum line differently, i stil in the end had tio plug up 1 vaccum line. so it didn't matter something still ends up not being right. does anyone know what happens when i go for a retest and fail?
thanks
-rafal
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
