LED Gauge Mod concern
Old Apr 1, 2005 | 07:45 PM
HarrisH's Avatar
I purchased 5 SUPER WHITE 194 CLEAR INVERTED LENS from superlumination.com we (SonicDust187) and I installed them in my gauges but they look almost purple and are not very bright... what gives??? My polarg hyper white 194 in the shifter (auto) (PRND21) also looks bluish rather than whitish... I want a super white look sorta like Wariow's gauges... what LEDS should I use??
Old Apr 1, 2005 | 07:51 PM
superblack98se's Avatar
www.superbrightleds.com Always worked for me
Old Apr 1, 2005 | 07:55 PM
HarrisH's Avatar
Yeah but what type of bulb should I get in 194 and does it have a tint of blue or purple?
Old Apr 1, 2005 | 08:27 PM
Dubaimax's Avatar
yeah i had the same problem... when u light them up like that, they're bright white, when they're in the gauge, they show bluish purple....
Old Apr 1, 2005 | 08:30 PM
HarrisH's Avatar
What bulbs did Wariow use his look superwhite...
Old Apr 1, 2005 | 08:31 PM
Nismotic's Avatar
Always sunny in philly
Use 194 super white Piaa bulbs...
Old Apr 1, 2005 | 08:43 PM
HarrisH's Avatar
http://autolumination.com/194.htm
I purchased the inverted lenses in superwhite I'm not sure how many MCDs they are autolumination says they are 13000 MCD superbrightleds says they are 390 MCD http://www.superbrightleds.com/1157.htm look under Single LED Wedge base bulbs and click on more info... should I get the WLED-X5???
Old Apr 1, 2005 | 08:51 PM
2 Da Max's Avatar
i bought mine from some dude in Hong kon off ebay, 2 for a dollar
Old Apr 2, 2005 | 01:50 AM
wariow's Avatar
it'll always be blue no matter what bulb you put in there, there's a blue tint on the back of the gauges but I told sonic before that if you use the inverted "white" led bulbs, they'll emit a very bluish color. Try getting some "hyperwhite" 194 bulbs and stick those suckers in. They'll still come out blue but not purplish.
Old Apr 3, 2005 | 07:25 AM
Max Mutes's Avatar
Hmm...the Polargs should have worked. I put them in my Gauges and they're the only ones to give me a Bright White output and I'm still using the black faces. P Henry said something about there bein a Blue VHT behind the Gauges, so I suppose it's in the Auto-Shift as well.
I wanna do my Gear select bright white too, have yet to try the Polargs tho. I sorta assumed they would work since they worked in my gauges...but guess not. Try another Hyperwhite like nisomtic said. DO NOT try those White LEDs off of SuperBright, cuz it will not be white. It will be very blue/purple like Wariow said. You need a tinted/painted blue bulb that emits a white light, to cut through the blue shield or whatever is underneath the surface. I even tried them Inverted ones off SuprBright in my Courtesy Lights, straight clear lense and they still were purple in color. Made no sense, but they suck.
Only problem I've had with the Polargs is I've had to take my dash apart a couple times to replace them after blowing out...made no sense. I put them in with gloves on so I don't know if that has happened to you or not.
Look at the RPM Gauge...Polargs compared to the Inverted White LEDs from SuperBright:
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
