New EGR valve and Check Engine light is on again!!
Old Jul 7, 2006 | 05:13 PM
  #41
stglock's Avatar
Folks,
Thanks to all who contributed to this thread. I had the pesky code P0400 , changed a whole bunch of parts (EGRC/Valve). Found out about this thread regarding this issue and what fixed it. The pipe with the temp sensor was the culprit. It was plugged with carbon!
Keep the good work!! -stglock
Old Oct 26, 2006 | 10:30 AM
  #42
airness_81's Avatar
I took my car to autozone to do a diagnose gave a idle contrl malfuntion,knock sensor,o2 sensor.After that they reset the ECM check engine gone.So i deside to change everything i can and clean everything to make my car run better.
I want my check engine back on again coz i cant take it to autozone to test it again im having a problem with my car i replace my 6 coil,6spark plug,Replace knock Sensor,EGRC Valve,Clean EGR Valve,Clean my trottle,Replace gas filter,Clean my MAF with Electric cleaner,Clean the Idle control valve spray with carbone cleaner i dont really know wat to do next.My car still miss firing,shutting off by his self.Any body knows wat else do i need to do after all the hard work for my car i spend to much know to buying some stuff that i dont really need and im still keep guesing wats the problem.Do any body knows when or how long the check engine back again?
Old Oct 26, 2006 | 03:25 PM
  #43
nitink's Avatar
Originally Posted by stglock
Folks,
Great!! My car have this code for long time and changed EGRC & lot of other things finally given up on it. can you please post picture of which pipe you are talking about.
Big Thankyouuu
Old Oct 27, 2006 | 11:23 AM
  #44
nhaven's Avatar
Big Thankyouuu
http://forums.maxima.org/showthread.php?t=496494
Old Oct 27, 2006 | 08:43 PM
  #45
nitink's Avatar
Thanks Nhaven, I got code P1400 from OBD2, is it the same thing as 0302?
Old Oct 30, 2006 | 10:21 AM
  #46
nhaven's Avatar
No, it is not the same. Unfortunately,I don't have the haynes manual with me right now. I think p1400 = 1005. Don't quote me on that one.
Try turning the screw on the ecu and see what pops up.
http://forums.maxima.org/showthread.php?t=104931
Old Nov 2, 2006 | 11:48 PM
  #47
nitink's Avatar
Thanks Nhaven,
p1400 is 1005, Anyidead what to do for this?
Thanks Again
Old Nov 4, 2006 | 10:13 AM
  #48
nhaven's Avatar
If you've done everything else, try cleaning the egr tube next.
Old Nov 9, 2006 | 07:00 PM
  #49
Khaman's Avatar
Originally Posted by jobell
Anybody ever replace an EGRC-BPT valve?? What does the part cost?? Also, how often do knock sensors go bad?? I located my knock sensor, but I'm not sure I want to tackle that job due to the location of the sensor.
Where is the EGR Control Solenoid Valve located?? If anybody has any pictures for the location of this valve, please post them. Thanks.
I need to konw where is the EGR Control solenoid valve located and pictures EGR Control solenoid valve
Old Nov 9, 2006 | 07:59 PM
  #50
shadyonedeath's Avatar
I fixed my 1005.
Took out the green Egr Solenoid and dis-assembled it, cleaned the metal peice/bearing inside and lubed it with silicone spray.
CEL hasnt came on for 3 days...
*south park* "Nice."
KHAMAN, look back about 3-7 pages, should be a thread about the EGR solenoid pics.
Old May 6, 2007 | 12:21 PM
  #51
aimwill's Avatar
My cel light came on showing a bad EGR & Knock Sensor trip!
With the car up to temp, I put my fingure under the egr (you can feel the rubber baffel), when I reved up the motor I felt it rise and then pump (pop pop pop) my fingure (Bad Solenoid).
I posted some photos on the location of the Solenoid.
So far the light has not returned.
It took me about 20 minutes to change.
I suggest removing the air box.
I was able to slide a .25" ratchet with a 10mm under where the radiator hose connects.
P.S. Let the engine cool (my hands hurt)!
http://vista.redirectme.net/maxforum..._solenoid.html
Old May 6, 2007 | 12:34 PM
  #52
gatorsteeler's Avatar
Originally Posted by knight71
I had the exact same problem as you..I replaced EGR valve and BPT valve..still CEL..Finally EGR solenoid valve was replaced..CEL free for almost a year now.
check this thread for info:
http://forums.maxima.org/showthread.php?t=357902
also:
http://img52.photobucket.com/albums/v158/evilBIGD/EGR/
those were useless need a password...ive been looking online for a good 2 hours looking for a vacuum diagram for my 99 max...no luck but my guess (as i have the egr code P0400) is that if you start cheaply troubleshooting the vacuum lines, then cleaning out egr and anything that might be clogged, u might not have to buy needless parts...oh, and if you need a vacuum diagram or any other useful diagram check the public library in the "reference" section as I will...its become quite evident to me that these cars have TONS of issues with emissions and ignition..go to library make copies keep handy...or pay $$$ going to shop every time that damn light comes on
Old May 6, 2007 | 12:41 PM
  #53
ah ha, the right link...basic diagram but better than nothing
Old May 6, 2007 | 12:44 PM
  #54
this thread should be saved...its got more info about this problem than any in the stickies i've read
Old May 6, 2007 | 02:40 PM
  #55
aimwill's Avatar
Here are color pics of the EGRC Location... I took them yesterday...
/maxforum/egrsolenoid/egr_solenoid.html
Old May 20, 2007 | 06:54 PM
  #56
konak85's Avatar
I've been getting codes 0409(oxygen sensor fault) & 0302. Are the two related at all? If so, which should i go after first?
Old May 21, 2007 | 12:32 PM
  #57
konak85's Avatar
^^^^bump^^^
Old May 28, 2007 | 02:50 PM
  #58
mlooking2's Avatar
No way is my Egr Pipe comming off.The bolts won't move at all. (Egr tube)
Old May 28, 2007 | 02:55 PM
  #59
mlooking2's Avatar
There are 3 oxygen sensors on my 96 Max I don't know how many on a 98/ but I would say there are 3. If you never changed them and have over 100,000 you should..I have 200,000 and changed mine twice. Looks like I'm going to pay someone to change my Egr tube as I can't get it off.
Old Mar 4, 2008 | 07:25 AM
  #60
Crusher47's Avatar
What are you guys using to clean the clogged tubes? Just regular carb cleaner? Do you run any risk of fires with this stuff? Thanks for all the great info.!
CorollaULEV
30
Aug 9, 2021 08:11 PM
lowpost99
22
Sep 2, 2015 04:38 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Samedi
Aug 13, 2015 04:05 PM
