!Emergency! brake experts help me please ..
Old Apr 3, 2005 | 03:36 PM
ThisMaxIsTight's Avatar
omg this is a nightmare...tried replacing back rotor and pads today...after the new rotor was put on..went to compress the piston but wouldnt compress, even with the special rear compressor tool...seems as if the piston is bad, we took the whole thing off and tried hard to compress it but it wouldnt budge..so my uncle somehow took the piston apart and fixed it(so we thought)...so we put it all back together and took it for a test drive...seemed fine..but 2 or 3 miles later theres a loud rubbing noise coming from the back brake area...is it a bad piston?...anyone know what would cause this?...can a new piston be bought at an autoparts store or do I need to buy from Nissan...PLEASE help me im stuck in jersey
Old Apr 3, 2005 | 03:40 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
they don't compress, you have to turn them in... just like a screw turn them in...
I can't help you if you took it apart though..
Old Apr 3, 2005 | 03:43 PM
Kevlo911's Avatar
Kevlo for President
I used needle nose pliars.
Old Apr 3, 2005 | 04:01 PM
yes we did turn them...sry compress isnt the right choice of words...tried turning it but the piston wouldnt even move back....would a bad piston cause pads to rub?
Old Apr 3, 2005 | 04:46 PM
pocketrocket's Avatar
Did you check to see if your slider pins were moving freely?
If your piston is stuck or your slider pin is jammed the wrong way, it will continue to press the pad on the rotor.
I changed my rear calipers a couple of weekends ago, $90 driver, $60 passenger from autozone w/ core return.
Old Apr 3, 2005 | 04:53 PM
joooowan
ok this is a stupid question but did you unscrew the cap off of the brake fluid resevoir?
Old Apr 3, 2005 | 05:01 PM
yes pocketrocket the caliper slider pins were all greased up and move freely....im not sure why the pads are rubbing but Im thinking the main brake piston is bad or something....cause OMG i forgot to say this-the old rotor had a serious flaw-the pad was only rubbing the rotor on like 3/4 inch of the rotor surface-there should have been more surface area contact between the rotor and pad...you can tell something was really wrong
Old Apr 3, 2005 | 06:09 PM
Intel's Avatar
Just bring them into autozone and get new calipers before you ruin all your new pads and such. I know on mine the pistons themself were all rusted out and would not move freely at all.
Old Apr 3, 2005 | 07:12 PM
Frank Fontaine's Avatar
Left and right cost different amounts?
Old Apr 4, 2005 | 04:49 PM
97maximaman's Avatar
hey, this is an awsome topic cuz my rear passenger caliper wont compress. Tried a c Clamp to compress it but no luck. Do i have to turn it in, or is my caliper frozen. please help. my rotors are grinding. if i dont get new pads on soon i'll have more epensive problems.
Old Apr 4, 2005 | 04:58 PM
dgeesaman's Avatar
Maintenance Monster
TWIST IT!!!
You can't compress a rear caliper!! You must twist it using the correct tool!!! Mine were slightly resistant, enough that I'm glad I had the tool. Needlenose pliers would have been very difficult.
Dave
Old Apr 4, 2005 | 07:06 PM
Since this requires a tool, anyone mind telling me what it's called because i cant find any such tool anywhere!
Old Apr 4, 2005 | 07:31 PM
dgeesaman's Avatar
Maintenance Monster
http://store.autotoolexpress.com/reardisbrakp.html
Autozone had them, but many service counter guys don't have a clue what it is.
Dave
Old Apr 4, 2005 | 08:12 PM
Autozone will loan them out to (you pay for the tool first, <$40, then you return it to get a refund). If they have no idea what you're talking about, this is the part number that showed up on my receipt:
#298604 27111 DISC BRAKE CAL $35.00 + tax
Old Apr 5, 2005 | 01:20 PM
Thanx a million. I'll try some robogrips but i doubt they'll work; if not autozone a right down the street from me.
Old Apr 5, 2005 | 02:03 PM
jome80627's Avatar
I had a similar problem and found it was cheaper to have the calipers rebuilt. After that was done, no more noises.
Old Apr 5, 2005 | 02:20 PM
njmaxseltd's Avatar
ThisMaxIsTight - You need to replace your rear calipers as they are binding up inside. Like some have suggested, go to AutoZone and take your old calipers with you so you don't have to pay the core charge. You should replace them in pairs for uniform braking.
Old Apr 5, 2005 | 04:22 PM
«§»Craig B«§»'s Avatar
not a good idea to use robogrips
you dont want to score or scratch the piston at all because it could cause damage to the seals if it gets scratched
buy the special tool for $10 at any auto parts store or use needle nose pliers carefully
Apr 16, 2020 05:15 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
