need help diagnosing weird sound
I have a stock 95 Max Se. Recently I've been hearing something that sounds like "bees in a can" I DO NOT have a y pipe and the sound is very loud. It seems like my stick shift is vibrating a bit more too. The sound gets louder with higher rpms when I'm stopped. At highway speeds i can't really hear it. After driving the car for about 12 miles on the highway, the sound seems to go away when I'm at idle. Anyone have any Ideas? Heat Shield?
You might be able to do this investigation in your own driveway if you have a good floor jack and four large (6-ton) jackstands. You don't need 6-ton for the weight of the Maxima, you need them because the 6-ton units will support the car at a greater height than the more common 3-ton jackstands.
thanks Daniel b...that's what I'm probably going to do
I wanted to clarify the sound. I think it actually sounds more like someone in the shower when I'm in the next room. Know what I mean. I guess water running through pipes in a house. Anyone else have any thoughts
tarun900
19
12-20-2021 06:57 PM
AaronL
08-08-2020 10:31 AM
Need help
23
10-02-2015 08:56 AM
HerpDerp1919
09-29-2015 02:02 PM
