Car won't start I need help FAST!
Old Apr 4, 2005 | 06:38 AM
GarciaMaxima's Avatar
I got in my car turned the key and it woulnd't start! the first few tries the car tried to crank but then all it does is a clicking noise when I trun the key!
HELP Please ( I tested the battery and that's not the problem)
Old Apr 4, 2005 | 06:55 AM
DragonMaxima's Avatar
Looks like you need a new starter.
Try banging it.
Old Apr 4, 2005 | 06:59 AM
maxgtr2000's Avatar
KH3 by popular demand
Hamma time!!!!
Old Apr 4, 2005 | 07:02 AM
Loe max's Avatar
the clicking noise is normally associated with a weak/dead battery. If you've tested the battery, test the alternator as well, it may not be full charge.
Old Apr 4, 2005 | 07:04 AM
suicidalspd99
sounds like the brushes in the starter are no good.
Old Apr 4, 2005 | 07:05 AM
how do I test the starter?
Old Apr 4, 2005 | 07:10 AM
Loe max's Avatar
The same way you tested the battery. Take out your multi-meter and check the resistance between both terminals with the ignition in the ON position. The voltage should drop now. If voltage drops below 11.5 volts, there is high resistance in the starting system. Check the connections to the starter or to the battery. If everything is 'ok', then its your starter.
BTW...Do you get a continous clicking noise? Do the warning lights flicker in conjuction with the continous clicking noises? If not, is it just a single click?
Old Apr 4, 2005 | 07:43 AM
tavarish's Avatar
fwd gone rwd cr00
The exact same thing happened to my mother's Kia. Odd enough as it sounds, see that the battery terminla sare on very tight and that there is no corrosion. if there is, then clean it off with baking soda.
Old Apr 4, 2005 | 07:45 AM
Loe max's Avatar
A bottle of coke works also
Did you try jump starting the car? I think there just isn't enough charge in the battery to fully start the car, hence why it'll crank, but stop right after.
Old Apr 4, 2005 | 08:26 AM
lex4style's Avatar
yea its either ur starter,battery or maybe your alternator.
Old Apr 4, 2005 | 10:06 AM
Ok I changed the starter and the car started right away.
Thanks guys
Old Apr 4, 2005 | 12:14 PM
Batxel's Avatar
blah
Thanks guys
Even though you already fixed your problem are you sure your battery is all right. The way you described your problem sounded exactly like my old car. My old car has been sitting for a year and was doing the same thing. I cleaned the crosion off the battery terminals and it started right up. It would attempt to crank and then start clicking.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
yat70458
Aug 3, 2015 01:16 PM
