Skyline VS 300ZX brake caliper BBK???
Old Apr 4, 2005 | 08:50 AM
MAXRB8's Avatar
Hey Guys, does anyone know the difference between Skyline r33 and 300zx TT 30mm calipers? Looking to do this conversion, I heard the r33's caliper body is physically larger?? and I believe the rotor for it is narrower on the r33?
Old Apr 4, 2005 | 08:51 AM
Jeff92se's Avatar
I'm needing a caw
Nope. I believe they are the same. I'd to the 300z calipers. Parts available from almost any parts store.
Old Apr 4, 2005 | 09:16 AM
Maximus_95's Avatar
yeah, go with the 300z calipers, they work awesome!
Old Apr 4, 2005 | 09:23 AM
MaximaSE96's Avatar
Maxima Owner
actually the skyline calipers are a little bigger....not by much....i know this because my friend did a skyline upgrade on his 300zx tt....so i am thinking if u can get skyline calipers u may not have to machine down 300zx rotors....or not as much...and u would want r32 calipers
Old Apr 4, 2005 | 09:30 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
PM sx7r... he attempted to install skyline calipers. They definately are different from 300zx - he had to machine the calipers... im just not sure on the details.
Old Apr 4, 2005 | 09:36 AM
Jeff92se's Avatar
I'm needing a caw
You don't need bigger calipers than the 300z. ESPECIALLY if you run the 13" cobra rotors.
Old Apr 4, 2005 | 09:39 AM
MaximaSE96's Avatar
Maxima Owner
well it depends what skyline calipers u use.....r32 are very similar to 300zx.....r33 and r34 are totally different..........in my opinion u dont even need 13" Cobra rotors either but he asked
Old Apr 4, 2005 | 09:59 AM
Jeff92se's Avatar
I'm needing a caw
Okay I did some research. The R32s are similar (if not the same as the 300z).
from tt.net:
Z32 280mm X 30mm
R32 GT-R 296mm X 32mm
R33/R34 GT-R 324mm X 30mm
The "Skyline" brake kit sold here in the USA is the R32 GT-R brakes. The R32 GT-R had 16" wheels just like the Z32, which is why their brakes will fit behind the stock Z32 wheels. The R33 and R34 GT-R used 17" and larger wheels, so they could use larger diameter rotors. As a side note, the R33 and R34 GT-Rs used 4 pot Brembo calipers, while the R32 GT-R and the Z32 both used Nissan (OEM) calipers.
Old Apr 4, 2005 | 10:01 AM
MAXRB8's Avatar
Exactly, I'm not looking for anything physically bigger than the 300ZX calipers as I know there's already going to be clearance issues, it's just there seems to be a rash of Skyline calipers on ebay listing as 300zx Calipers!
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Thanks to help from various people on the org especially Jeff92se & Automax, I'm trying to do some spade work so I don't screw up and buy something I can't use, I'd really like to go to the 13" rotor but I want to make sure I have proper clearance and if the R33 calipers are bigger that only compounds the problem. I'm still searching for a good deal on a set of 300zx TT calipers
Old Apr 4, 2005 | 10:11 AM
jblinga's Avatar
I got mine from Centric Parts in Ca, brake parts warehouse. They were remanufactured & the cost was around $300, I also got patial core credit for my stock 96' Maxima calipers which took the overall cost of the 300ZX TTcalipers to around $220.
Old Apr 4, 2005 | 10:26 AM
adithius's Avatar
Will the stock Maxima caliper brackets be compatable with the 300zx caliper?
Old Apr 4, 2005 | 10:30 AM
MAXRB8's Avatar
The brackets are removed when installing the 300Zx caliper
Old Apr 16, 2005 | 09:00 PM
DeusExMaxima's Avatar
Will 300ZX calipers bolt on to 6th gen Maxima (2004-2005)?
Old Apr 12, 2008 | 12:32 PM
GAMERA30's Avatar
From: Long Beach, CA is where i live. Queens NYC is always home.
Nope .... alredy tried that retrofit.^the 6th gen used a larger 14mm bolt. 300zx used a 12 mm. Asside from that.U need bracket/adapter from Jeff or Matt
Old Apr 12, 2008 | 12:57 PM
pmohr's Avatar
No more Maximas...
I'm sure he'll care, given that he posted 04-17-2005.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
