RPM issues
RPM issues
I was driving yesterday after finally getting my car back on the road. (I just changed my valve cover gaskets which was my first major engine project and took me a week and a half) While I was driving I noticed it ran rough and almost stalled if I let off the the gas all at once. That's almost the way it was acting when I had my bad MAF sensor. Later that day I hit the gas and it went up to about 5500rpm then twitched back to 4500, and completed the power band normally after that. AGAIN that same day the O/D off light started strobing on and off for a few seconds then stopped. As I mentioned I just changed the vc gaskets and I am new to engines is there anything I could have screwed up? I also did the ghetto air box mod not too long ago, and I have an electrical short somewhere in the dash from having the gauges out without disconnecting the neg battery terminal (stupid mistake I know).
any ideas??
any ideas??
Get the code read. flashing OD light = TCM has detected a problem. This code can be read from the SES/CEL light, BUT it's a general TCM malfunction code and doesn't help you zero in on the problem. That is why you need tog et the 'OD' light read.
Theres a way to manually check this while sitting in the car; using the OD Light and how many times it blinks can determine the specific issue.
This is also in the Hayne's manual and explains how to go about doing this
shilov
02-19-2024 09:40 PM
