symptoms of a bad PCV valve
So what are they? I'm wondering because I didn't have mine replaced at 60,000 miles, as is indicated on the service bulletin (I had everything else done though) and my car's been acting a little weird lately (rough idle and the engine, in general, seems to be noisier).
Originally Posted by maximus_96
its so cheap you shouldn't really need to debate whether to change it or not.
Question: What is the purpose of the PCV valve and what are the symptoms when it goes bad?
Answer: PCV means positive crankcase ventilation. This valve uses vacuum from the intake manifold to draw the fumes from the crankcase. Symptoms of a faulty PCV valve are poor idle and excessive pressure in the crankcase.
8 bucks shipped or something liek that at JR nissan. Just warm up the car a little to have the hoses a little warmer and softer. I had trouble getting the hoses off. and make sure you keep the clamps on the hose and not fall into the engine bay. I just used duct tape to keep it up while I re-did it. I had a smoother idle after that, but for only the first couple hundred miles.
