What should i do SUGAR IN MY TANK
Old Apr 6, 2005 | 02:39 PM
  #41
PAREDLINE's Avatar
Remove the bottom portion of your rear seat. You'll see a triangle on the floor when you remove it. Remove the screws and that triangular metal plate. Under there is a ring with more screws and two hoses going into a pump along with an electrical harness. Remove the hoses + unhook the harness. Remove the screws.
Pull out the fuel pump/fuel sender unit assembly. You will see the inside of your fuel tank underneath. Using a hand operated pump, pump out all the gasoline.
The sugar will come out too. You can then clean the inside of your tank and allow it to dry before you refill the tank with gasoline.
You will smell. Make sure you have a fire extinguisher handy
Old Apr 6, 2005 | 02:45 PM
  #42
Ant96GLE's Avatar
Your screwed because once the engine sucks it up........... I mean
I guess no one reads before they post... auto banage
Old Apr 6, 2005 | 03:11 PM
  #43
Supermax95's Avatar
i think putting a bunch of soda in the tank would have been much more harmful.....=P
Old Apr 6, 2005 | 03:18 PM
  #44
Ant96GLE's Avatar
Yea or water...
Old Apr 6, 2005 | 04:10 PM
  #45
Ninos_Maxima's Avatar
be the change u want2C
Wait isint this what the fuel filter is for???, You should be fine I think
Old Apr 6, 2005 | 04:23 PM
  #46
Skiptronic's Avatar
Hahaha man what the hell did you do to her?
Old Apr 6, 2005 | 04:38 PM
  #47
SPiG's Avatar
SomePsychoGuy
Water and soda won't dissolve in the gasoline. It will just sit at the bottom of the tank. You would have to be pretty low on fuel unless you put several gallons.
To do something like this you would need something oil soluble and in some way damaging to the engine internals, i.e. something corrosive or non-compressible.
BTW Bleach in the oil will kill the motor. It may work in the gas tank but not nearly as fast or as effective.
Old Apr 6, 2005 | 04:52 PM
  #48
Ant96GLE's Avatar
Any water in the tank is bad. During the winter you usually want to fill up when your tank is down to 1/2 atleast so water doesnt condense inside of the tank.
Old Apr 6, 2005 | 05:11 PM
  #49
Maximus_95's Avatar
that is why, girls and cars dont mix!@
Old Apr 6, 2005 | 05:28 PM
  #50
TheFink's Avatar
Nothing will happen. I was lucky enough to catch an episode of mythbusters and they did a sim. that used all sorts of stuff in a gas tank, including sugar. They said that if it did anything, it made it run better...hope the case is the same for you!!
Old Apr 6, 2005 | 05:34 PM
  #51
TheFink's Avatar
Originally Posted by pavelsmax
yea it was on mythbusters... the left the engine running all night long and it didnt have any effect on it... til they added the bleach
guess i need to read all the posts before i make one, sorry for the double!
Old Apr 6, 2005 | 07:22 PM
  #52
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
damn, bro that really sux. girls are nothing but trouble anyway.
here's another way to get even. you and some friends should go to her house during the middle of the night, in another friend's car of course, take a paintball gun, fill it w/ diff. colored paintballs, and get her car good w/ paintballs
Old Apr 6, 2005 | 07:28 PM
  #53
maxdick's Avatar
Originally Posted by MaxInProgress
if you ran the motor with the sugar inside the fult tank say goodbye to your car........and your engine, i hope u havent ran it too much.....
I saw on mythbusters that even if it gets to the engine it doesn't really do much damage. Sugar in your oil might **** **** up though.
Old Apr 6, 2005 | 08:07 PM
  #54
konak85's Avatar
siphen the biatch
Old Apr 6, 2005 | 08:19 PM
  #55
AlexI30's Avatar
My vote goes for the cement powder on the car, sounds like the only thing she could do is blow it off (and probably still get some scratch marks), and what are the chances that'll be the first thing she thinks of?
or just take the bolts off a front wheel, but leave the wheel on the car.
Old Apr 6, 2005 | 08:22 PM
  #56
notsofun's Avatar
Yeah sugar isn't bad think of what a low melting point it has as soon as it hit the combustion chamber the stuff would be pure liquid....
Old Apr 6, 2005 | 08:31 PM
  #57
IWishIHadADub's Avatar
You don't mess with people's cars. Ever. I loathe people that do. Here's what you do. Walk up to her... say what's up. Then back hand the **** outta that *****. Women want equality, so I say I can hit them too.
Old Apr 6, 2005 | 08:58 PM
  #58
MrDicks95SE's Avatar
Offset Is Everything.
uh when sugar's heated up it becomes all sticky and isht. so try to suck it out with a hose or soemthing or else your engine internals are gonna get nasty. eh itd taste sweet anyways if you got it into your mouth
Old Apr 6, 2005 | 09:02 PM
  #59
The Russian's Avatar
THATTS SHADY, ID **** ON HER FRONT RIGHT TIRE, near air conditioning vent, so her car would smell for the rest of the time she had it, then id totally put cement into her gas tank with a lil post it that said "hahahahahhaha now what bit*ch" over the cement, then id seriously take a **** in a bag and light it up, and put it in her trunk, so shed ahve a nice smell in back, then id write "WHOS THE ***** NOW" on the hood.. if u need any more ideas hit me up
Old Apr 6, 2005 | 09:04 PM
  #60
tonelocnyc's Avatar
damn son..knock that biatch
Old Apr 6, 2005 | 09:10 PM
  #61
Jar's Avatar
Jar
yep, they also did that on myth busters, they poured a whole bag of suger in the tank and ran it with out it popping the motor, just drop the tank clean it out, clean the "sock" and change out your fuel filter. and i'm not for violence at all but that ***** could use a "smackin" simply for being the type of person to attack someone through their car.
  #62
Rent a woodchipper and push her in.
Old Apr 6, 2005 | 09:14 PM
  #63
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Originally Posted by Jeff92se
LOL here let's make it easier for everyone. People don't like to read.
Dear Tom and Ray:
I put sugar in my husband's gas tank, but the car has not been turned on yet. Is there any way we can get the sugar out or neutralized? -- Susan [bluecar.gif]
Tom: Let me start by reminding you that, someday, Susan, the two of you are going to laugh about this.
Ray: But probably not as hard as we're laughing now!
Tom: Here's the story, Susan. A lot of people believe that putting sugar in a gas tank will ruin an engine. In fact, that's undoubtedly what you thought when you dumped that 5-pound bag in there (I'm sure he deserved it, Susan).
Ray: We know that sugar does not dissolve in gasoline. And there's an old myth that sugar will "caramelize" once it gets into the cylinders and turn your cylinder walls into peanut brittle. But the truth is, it'll never get as far as the engine.
Tom: Right. There are several filters between the tank and the engine that are designed to stop exactly this type of contaminant from reaching the engine. There's a "sock" at the end of the pickup tube in the gas tank, and there's a gas filter further up the fuel line. And the sugar will be stopped there.
Ray: It will, however, almost certainly plug up the fuel filter and stop the car from running. And, depending upon how much sugar you dumped in there, you might have to replace the fuel filter -- and get stranded -- several times before you clear it all out.
Tom: So you really should get the sugar out of there. And the only way to do it is to remove the gas tank, turn it upside down and dump it out.
Ray: You'll have to have it towed to a gas station, since you don't want to run the engine. Any decent mechanic can drop the tank and clean it out for you. It's not a huge job, but it's not something you're going to do yourself. It should cost you between $100 and $200.
Tom: And next time, think about doing something more easily reversible ... like putting itching powder in his shorts.
Changing your oil regularly is the cheapest insurance you can buy for your car, but how often should you change it? Find out by ordering Tom and Ray's pamphlet "Ten Ways You May Be Ruining Your Car Without Even Knowing It!" Send $4.50 (check or money order) to Ruin, P.O. Box 536475, Orlando, FL 32853-6475 or order online now.
Old Apr 6, 2005 | 09:24 PM
  #64
rsly33's Avatar
Haha yeah ok how old are you? 17? Have fun when that girls dad shoves a gun in your mouth.
Old Apr 7, 2005 | 11:25 AM
  #65
FormorAccordMan's Avatar
Ha you just made me laugh out load at work. People are looking at me funny. I was just picturing it in my head...thanks for the laugh.
Old Apr 7, 2005 | 11:34 AM
  #66
joooowan
*** fixing it. sue the girl and make her buy you another car
Old Apr 7, 2005 | 11:44 AM
  #67
JetBlackMax83's Avatar
Good suggestion
^^HAHAHAHAHA
Id recommend you not take any further action to her because women will always come right back and do somthing worst trust me I know she will come back and do somthing worse just be thankful that this doesnt really effect your car that bad just swap out you fuel filter and go to your local home depot or lowes home improvment and rent a wood chipper
ef9
Oct 4, 2015 08:43 AM
220k+ A32
Sep 23, 2015 03:38 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
jerrod99_se-l
Sep 16, 2015 02:39 AM
