clearance(corner) lights
Old Apr 6, 2005 | 01:35 PM
Supermax95's Avatar
Where is the fuse for these lights? both of mine went out but i cant find the fuse. there is a spot in the box on the left hand side of the engine bay that says "corner lamp" but there is no relay in there....
Old Apr 6, 2005 | 01:48 PM
90stanza's Avatar
my corner, fogs and tails went out last night. I almost flipped sh*t but I found the fuse. Check the fuses to the left of your steering wheel inside your car. If you find one that is blown replace it with one of the spares and see what happens
Old Apr 6, 2005 | 01:53 PM
Supermax95's Avatar
hmmmm....so they all went out at the same time?? they share a fuse??
Old Apr 6, 2005 | 06:27 PM
90stanza's Avatar
well i have my fogs re wired to my side marker lights so thats probaly why.
Old Apr 7, 2005 | 12:48 AM
acommondesire's Avatar
I know this isn't the right thred for this post but I was wondering if the Nissan Maxima 4G's headlights fit on a Infiniti I30, and if they do, where can I if they even exist get some projector headlights. I would search but it wont let me do that either. Thanks.
-Spike
Old Apr 7, 2005 | 07:26 AM
BLaKtOut's Avatar
the fuse for the corner lights is located in the fuse box under the steering whell its all the way on the first row check for the A/T fuse its a 7.5 right under or above that one it will way Tail L 7.5 on ur little box take that one out i should know i just replaced mine
Old Apr 7, 2005 | 07:38 AM
Jatan's Avatar
Happened to me a month or two ago - there are 2 "tail light" fuses in the fuse box under the steering wheel and it should be one of those 2 (I think the lower one of those 2)
I'm also guessing that your brake lights don't dim when you turn on your headlights?
lowpost99
Oct 26, 2025 06:53 PM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
