Major Major light issues now!
ok so by now everyone probaly knows that my car was stolen and striped....ok i got 90 percent back together......
first day i found my car.....all interior lights work..
the only wire they cut was the back wires that lead to the trunk because they stole the dam trunk, all head light would work and interior,
today i realize i moved the turn signal and it flicks very fast-thats wierd because when i moved it the last time there was no flicking and all the dash lights were working and switches.....
so this is wat happens now i can see the bose and the ac lights working but as soon as i turn the head light the bose and ac goes off but the clock always work. and oh yeah the cluster light don't go on!
what can cause the light to do this? fuse? relay? any suggestions?
The fast flashing signal is normally there to tell you that your bulb needs to be changed soon, however back in my hon-duh days, we used to short the power to the turn signals and cause both of them to blink really fast. So if replacing the bulb doesn't work, look for a short in that circuit. As for the rest, I would check your fuses and check your dimmer switch, I also had a dimmer switch go out on my old J30 and the cluster wouldn't light up until I changed it.
trasmadean
Jan 20, 2018 05:05 AM
check your dimmer switch. Also the reason for a fast flashing turn signal is because either the front or rear bulb is out.
