keyless remote entry problems
Old Apr 8, 2005 | 10:32 PM
Nissan2k5's Avatar
well my keyless remote entry stopped working i was thinking maybe it was cuz of the battery. so i changed the battery but it still was not working. i took it to the nissan service place they said the pad would cost 110 and to reprogram the **** would cost 45. should i just get a new alarm or can u guys help me with this problem. thanks
Old Apr 8, 2005 | 10:50 PM
MaDMvD's Avatar
I'm afraid we're going to need a few more details. Does it not work at all? Have you tried looking through your fuses, to see if any are blown? If that's not the case, I'd try reprogramming it myself. I've seen the instructions on how to do it, but I don't have it saved. I'm sure someone can provide you a link. Finally, if that doesn't work, I would buy another remote, either from the parts forum, or off eBay. They shouldn't be more than $35-$50. Good luck!
Old Apr 8, 2005 | 10:55 PM
Nissan2k5's Avatar
fuses hmm didnt check that im an idiot ill check it in the morning
Old Apr 8, 2005 | 11:06 PM
MaDMvD's Avatar
It happens to all of us. I hope it's just a fuse!
Old Apr 8, 2005 | 11:35 PM
Fekz's Avatar
I don't remember where on the org i got this (think how to's/faq), but credit to whoever created it.
Q: How do I reprogram the Keyless Remote?
A: Here's the procedure from the 1995 Factory Shop Manual
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
remote controller or multi-remote control unit LCU05 is replaced.
an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
I had to do this when I bought my maxima, so I know it works. Hope this solves the problem
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
