Clock cutting out / not working
Old Apr 10, 2005 | 12:53 AM
AceO's Avatar
I keep hearing that this is a common problem, but can't find anything in the stickies...
The clock on my 97 SE is going weird - sometimes it works, sometimes stays blank
When blank, sometimes pushing the defog/blinker button would turn on the clock
Question, is this common, and is there a 'standard' way to fix it?
Also, if the clock is dead, do the blinker/defrost buttons still work?
Thanks.
Old Apr 10, 2005 | 12:57 AM
Crockpot's Avatar
take out the clock, take it apart and see if there are any loose connections. If there are just re-solder them down. Yes, the defroster and yeild buttons will still work if the clock is out.
Old Apr 10, 2005 | 01:01 AM
MystA RavE's Avatar
same problem here...I took the clock out and everythin seemed fine but the connector wasnt staying in place too well to keep it on all the time. I taped it up and put it back but now its the same way it was, the solution was only temporary. I gave up on it, its not that important to me
Old Apr 10, 2005 | 09:54 AM
AceO's Avatar
Thanks guys. I guess that FSM from PhatG20.net will come in useful now
Anything in particular I should be on a lookout for in there?
Old Apr 10, 2005 | 11:19 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
now i have a good one for you.
what if you have no loose connections and only when the stereo hits the clock dims, not like the dash lights but almost to nonextinction then comes on regular brightness and alternates, but not with the beat almost like it is on its own with te bass as a catalyst.
Old Apr 10, 2005 | 01:29 PM
Panick's Avatar
The clock on my 95 was crapped out when I bought the car. Rather than pay $50 for a replacement, I just went and desoldered and resoldered all the connections. It took about 45 minutes total. I also had to replace the one capacitor. After that the clock works perfect. Or you could just buy an aftermarket radio with a built in one and screw Nissan's crappy clock.
Old Apr 10, 2005 | 03:56 PM
90stanza's Avatar
has any one had a problem with there lets gonig out in the air control unit. The led lights work but the back lights seem to dim and go out. It started to happen when my sub was on and now they just stay off. Any suggestions?
Old Apr 10, 2005 | 04:01 PM
A32Matt's Avatar
I got fed up with mine so i took care of the problem as you can see.
Old Apr 10, 2005 | 04:06 PM
Panick's Avatar
That looks sweet. Mind if I ask how you did it? What was the wiring setup for the lights and such?
Old Apr 10, 2005 | 05:11 PM
Crockpot's Avatar
wtf is that??
edit: nvm, just looked at ur home page..
Matt93SE
Apr 8, 2018 09:23 AM
vingodine
45
May 21, 2016 12:46 PM
kmitchel
Oct 28, 2015 09:46 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
