What the heck is this?
Old Apr 10, 2005 | 05:00 PM
mendon99's Avatar
tastey wheat
While reaching my arm in to get the jack-bar (i figured it had fell back there or something), i pulled out these rubber hoses.. what are they? i don't have any idea what they could possibly be hooked up to.. are they important? they were just dangling there..
Old Apr 10, 2005 | 05:07 PM
Crockpot's Avatar
I'm takin a stab and guessing sunroof draining lines
Old Apr 10, 2005 | 05:09 PM
NmexMAX's Avatar
dot dot dot ...
Antenna hardware stuff ...
Old Apr 10, 2005 | 05:12 PM
mendon99's Avatar
tastey wheat
lol maybe thats why my antenna is running so crappy
Old Apr 10, 2005 | 05:17 PM
Terran's Avatar
they're definitely drain hoses. I think for the sunroof. I have them too.
Old Apr 10, 2005 | 06:36 PM
2 Da Max's Avatar
is that why my trunk by the spare is wet? btw i know one of the hoses connects to the antennae motor
Old Apr 10, 2005 | 07:04 PM
shmad's Avatar
i think they are sunroof draining hoses. if they get clogged up ur sunroof will leak into ur car. happened to me when i had an old prelude.
Old Apr 10, 2005 | 07:23 PM
99se5spd's Avatar
yup, the larger hose is a drain for the sunroof (there is one in each corner of your car) and the second smaller one is a drain for the power antenna, there should be a grommet back there that they stick into, dont let them just hang there or your trunk will fill up with water...actually as long as they are out make sure they are clean also.
Old Apr 10, 2005 | 07:25 PM
mendon99's Avatar
tastey wheat
alright sweet. thanks all
Old Apr 10, 2005 | 08:04 PM
DragonMaxima's Avatar
Anybody know where the drain tube is for the front driver side?
When it rains it seems like my headliner get's a little damp. It's where the A-piller meets the headliner.
Thanks.
Old Apr 10, 2005 | 08:12 PM
99se5spd's Avatar
Thanks.
pull up the door sill by carefully pulling straight up, than pull the kick panel off (next to the "dead pedal") by pulling towards the radio, reach in a hole out there and pull the tube out and clean, or open the roof and use compressed air to blow into the holes in each front corner.
Old Apr 10, 2005 | 08:13 PM
2 Da Max's Avatar
hhm sounds like the windshield bro
Old Apr 10, 2005 | 08:22 PM
I tested my theory by pouring water directly into the top left hole in my sunroof, so I'm pretty sure it's coming from there.
I will try the compressed air.
Thanks.
Old Apr 10, 2005 | 11:50 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
I have the same problem. You can try sticking a coat hanger down the tube, but make sure you curl over the coathanger end so it won't puncture the rubber tube.
The Wizard
24
Oct 1, 2015 08:47 PM
sliptap
Sep 30, 2015 05:57 AM
05RLS2
Sep 27, 2015 09:24 PM
kling's maxima
Sep 3, 2015 04:45 AM
Stelianos
Aug 19, 2015 02:07 PM
