Do I have Locking Differential ?
Old Apr 11, 2005 | 11:25 AM
renatonetmail
How do i know or check? and what's locking diferential?
yeah... i know.... but oh well
Old Apr 11, 2005 | 01:21 PM
Bobo's Avatar
You mean limited-slip differential. I have it as my car is for the Canadian market. Do a search. This has been already been discussed ad infinitum in the last two weeks. I would be willing to bet that you do not have it.
Old Apr 11, 2005 | 01:54 PM
MDeezy's Avatar
if you can find and post the tranny code up here that will tell us what type it is.
But more than likely assuming its a US Max, you have a Non-Locking Differencial (Open Diff).
A locking differential is where the rear tires are locked what ever speed one wheel is moving so is the other their locked together. (if my definition isnt spot on jump in)
Old Apr 11, 2005 | 01:58 PM
SPiG's Avatar
SomePsychoGuy
If your tranny code ends with?
V = Viscous LSD
A = open Diff
If when you jack both front tires up off the ground and spin one, do they spin in the same or opposite directions?
same = LSD
different = open or your LSD isn't working
Most LSD came in Canadian maxs, I30 5spds, and 01 AEs. If you don't have one of those then you probably don't have one.
Old Apr 11, 2005 | 02:05 PM
Entropy's Avatar
Yeppers.
Doesn't matter which wheels. It'd be front wheels for our cars, but I've never heard of anyone locking one of our diffs.
Air, Electric, or Lincoln Lockers all lock the two wheels so that they turn at the same rate. To the point where, depending on conditions and tires, you could get wheel hop going around a corner.
There is a liquid one too - Viscous Coupling? I think that's where there is liquid that locks discs instead of spider gears similar to the more mechanically permanent methods - but that one is a little foreign to me. It works at low speeds to prevent wheel spin but disengages somewhat at high speed.
Old Apr 11, 2005 | 04:20 PM
pavelsmax's Avatar
yea since i had the 4x4 look goin already i threw some detroit lockers on there and a dana 60 axle... next im takin off my fenders and goin muddin
lockers are for trucks... cars have limited slip and i guess some cars mite have locking differentials but none i know of
Old Apr 12, 2005 | 11:52 AM
renatonetmail
and I can find the tranny code in......... ???
Old Apr 12, 2005 | 02:42 PM
genepool's Avatar
you can find the tranny code on the firewall in the engine bay...something like RE404V
James92SE
142
Jan 2, 2024 09:23 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
Pied
Sep 26, 2015 03:29 PM
ajahearn
Sep 19, 2015 03:03 PM
