Any Reason Not to get 99 if want to mod
Old Apr 12, 2005 | 02:07 PM
Mymax97's Avatar
Hi
Just like the title says. Found a 99 max 5spd 56000 miles for only 6k could be alil cheap so i gotta go see it. But besides the ecu because that cant be upgraded i believe (correct me if im wrong) but is there anything else on why not to get the 99 max Se with leather?
Old Apr 12, 2005 | 02:33 PM
ewuzh's Avatar
The coilpacks (going bad) tend to be more of an issue on 99 model maximas Also there are two different emissions specifications for the 99 model (federal and california). Aftermarket y-pipes eliminate the two precats from the stock y-pipe. If you get a cali-spec emissions 99 model, then only one precat can be eliminated (less power gain potential). Try reading the FAQs.
Old Apr 12, 2005 | 02:34 PM
Chief Brody's Avatar
Sounds like a good deal. Be sure to check it out with a fine toothed comb. The ECU upgrade is the only drawback I can think of, but you will be getting a newer car with low miles. Anything wrong with your 97? It may be a hassle to try to sell your current car and you are incurring some risk buying a used car as always. Guess it depends.
Old Apr 12, 2005 | 02:42 PM
Ninos_Maxima's Avatar
be the change u want2C
^JWT has a ECU for 99s now
Old Apr 12, 2005 | 02:43 PM
Mymax97's Avatar
Hi
Well i think that i have a buyer for my car. I did read the FAQs i was just wondering if there was anything else. I knew about the coilpacks i just forgot to mention them in the orginal post. Thanks for the info tho. Is the 3.5 ecu upgrade able since i might put the whole 3.5 in my car?
Old Apr 12, 2005 | 02:44 PM
NmexMAX's Avatar
dot dot dot ...
It's almost a domino effect with the ecu though, b/c then it leads to ECU upgrade/extended limiter etc, but still a 00vi with an ecu will still give better pwoer under the curve as well as 5k+
BlueC's Avatar
wat
Show me, I havent heard of any....
Old Apr 12, 2005 | 02:46 PM
Kevlo911's Avatar
Kevlo for President
WTF how did you find out? Who told you? I need details.
Old Apr 12, 2005 | 02:49 PM
NmexMAX's Avatar
dot dot dot ...
I got an ermail from Ben Pila (frm JWT)
Dated 3/10/05
"We have not completed our long term development of ECUs for 1997+ model Maximas. The 1997-99 style ECUs are the next ones to be completed in the future. It is unknown at this time exactly how long before the 2000+ model ECUs will take before we can begin upgrading these." JWT is close how's TS?
LAter on it goes to say about using the 95/6 in the 97-8 but not 99
Old Apr 12, 2005 | 03:18 PM
Zack342's Avatar
i called JWT today and spoke to both Ben and Clark. you can make a 1996 maxima ECU work in 1999 maximas.
Kevlo911's Avatar
Kevlo for President
If you figure out how to dissable hte immobilizer, you can swap some ECU pins and it will work fine
Old Apr 12, 2005 | 03:19 PM
MaxxAddict's Avatar
Dated 3/10/05
Um, it specifically says that they are currently WORKING on 97-99 ECUs. They aren't ready yet to be sold.
I dunno what all this 1997-1999 ECU BS talk is all about.
Old Apr 12, 2005 | 03:21 PM
MaxxAddict's Avatar
exactly. that's not the point tho.
The point is that there is no 1997-1999 JWT ECU that can be simply connected w/o a CEL and fabrication.
Old Apr 12, 2005 | 03:40 PM
Mr.Duck's Avatar
supposidley you can put in a 96 ecu and have no problems, there is a guy who did it, and is waiting to install it in his 99, we are waiting to hear back from him at the moment.
Old Apr 12, 2005 | 03:46 PM
NmexMAX's Avatar
dot dot dot ...
Oh well, I got mine on my 95 no probs, jsut trying to help out
Old Apr 12, 2005 | 03:58 PM
Coilpacks like everyone else said. My went bad and I just ordered new ones for a whopping $355.
Also, the Stillen SC kit is not CARB approved for 99's.
On the bright side, 99's have outside temperature display.
And they came with Traction control as an option (very rare and hard to find)
James
Old Apr 12, 2005 | 04:01 PM
AceO's Avatar
but dude...you can get it in Crimson Blaze red...that alone is worth it
Old Apr 12, 2005 | 04:18 PM
Mymax97's Avatar
Hi
Thanks again for the input. Although the 99 max that i found was silver and not the red.
AboveDaCloudz
Oct 8, 2015 11:25 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
