Ox Sensor(s)
Originally posted by zaebis
I heard that failure of Ox Sensors is quite common in Max. So I was wondering what the simptoms of that failure are? ...
1) The Oxygen Sensor is "dead".
The signal from the Oxygen Sensor is outside the normal range, or completely absent. The Engine Control Module (the computer) turns on the Malfunction Indicator Light and stores one or more Diagnostic Trouble Codes. This failure mode is obvious because of the dashboard warning light.
A dead Oxygen Sensor is a severe failure and should be repaired promptly.
2) The Oxygen Sensor is "tired".
The Oxygen Sensor still works but it responds slowly to changes in the oxygen concentration in the exhaust stream. There is no MIL or DTC. This failure mode is less obvious. The symptoms are increased fuel consumption, decreased engine power, and a feeling of sluggishness. The throttle response is not crisp, like it was when the car was new. An Oxygen Sensor may become tired due to high mileage or being "poisoned" by exposure to various substances including leaded fuels, anti-freeze, anti-seize, RTV sealants, and the residue of burned engine oil. A "tired" Oxygen Sensor is still doing its job, but not performing well.
A tired Oxygen Sensor is not a severe failure and the car may be operated safely.
You may have your Oxygen Sensor(s) tested. There are electronic testers made for this specific purpose. In addition, a technician with an automotive oscilloscope can test Oxygen Sensors. The signal from a healthy sensor varies from a low threshold (around 0.2 volts) to a high threshold (around 0.8 volts), and it sweeps back and forth between those extremes about 10 times per second. If the scope trace shows the Oxygen Sensor signal failing to reach either extreme, or oscillating between them at a frequency slower than 10 cycles per second, that is evidence of a "tired" sensor.
For more information about Oxygen Sensors see:
http://www.volksparts.com/o2sensors.htm
http://members.aol.com/carleyware/library/o2sensor.htm
TallTom
50
07-08-2022 09:54 AM
my03maxima
04-29-2020 12:48 AM
Kyle Lee Cleveland
09-28-2015 09:01 PM
