Power loss, no codes, not knock sensor?
Old Apr 13, 2005 | 10:52 AM
dewi1219's Avatar
My '99 SE has experienced a pretty major (but inconsistent) power loss. Sometimes it runs normal and somtimes it loses power, and it surges back and forth between the two in a split second. I had the codes checked twice and there weren't any. The plugs and fuel filter have been replaced, and I tried the knock sensor bypass (470k resistor), but nothing has changed. Any ideas? Thanks.
Scott
Old Apr 13, 2005 | 10:55 AM
Jatan's Avatar
Coil packs?
Old Apr 13, 2005 | 11:01 AM
dewi1219's Avatar
I'm pretty sure it's not the coils because it runs and idles smooth. I have a friend who also has a '99 and his coils are bad. His runs and idles very rough, but mine doesn't.
Old Apr 13, 2005 | 11:20 AM
Maximized Jiggs's Avatar
Are you using regular or premium gas? Run some fuel injector cleaner too.
Old Apr 13, 2005 | 11:36 AM
dewi1219's Avatar
I should've mentioned that - I am using premium fuel and I have run two bottles of Lucas injector cleaner through it. No difference.
Old Apr 13, 2005 | 11:56 AM
S103100F's Avatar
same story no codes but loss power
plz help i was thinking injectors but i want to know 3 things is there codes for them and how hard it is to check them and how effective is to clean them do they work like new or i am beater of getting new ones?coz they cost mad money
Old Apr 13, 2005 | 12:00 PM
I replaced all my injectors because I would get constant engine misfires. If you dont have a rough idle and the car does not misfire at all then dont change them. Get a shop to clean them or keep running injector cleaners.
Old Apr 13, 2005 | 12:39 PM
tavarish's Avatar
fwd gone rwd cr00
could be your MAF sensor calling it quits...
Old Oct 9, 2008 | 10:09 AM
gyrostylez's Avatar
what is the verdict on this? I'm experiencing the same thing.
Old Oct 9, 2008 | 10:22 AM
mtwoody13's Avatar
i had the same problem for about a year, no codes and was so random that it took the shop about a week to find the problem... i ended up having to put a new ecu in it, havent had a problem since.
i hope its not that, it aint cheap
Old Oct 10, 2008 | 09:15 AM
crash_landing's Avatar
do you hear the injectors "clicking" for each cylinder when you have power loss? check the grounds, especially the ones for the injectors and the coils. I replaced all my coils and platinum plugs bc of one bad injector....
have you checked that all of your belt driven crap if functioning properly and not yanking power....
Old Oct 10, 2008 | 09:17 AM
fourstaroots's Avatar
MAF sensor?
Old Oct 10, 2008 | 07:12 PM
SE01Maxima's Avatar
I would have to agree...I had the same intermittent problem on my 01 AE for about 6 months and it ended up being the MAF sensor.
Old Oct 11, 2008 | 08:14 AM
JtzMax's Avatar
Whatchyou say?
Make sure your MAF sensor is plugged in good and make sure your air filter is clean / new. Clean the TB (I recomend pulling the TB off of the intake manifold and doing it that way) and see if your problem persists. It is possible the Mass Air Flow sensor is going, but usually once it goes, it's gone - will not go then come back, then go ... etc.
Do you get surging from the engine? How's the idel and what about holding it at ~2k revs, any hicups?
Old Oct 11, 2008 | 10:32 AM
knight71's Avatar
Tape your coil packs and see if that helps..check these 2 threads:
http://forums.maxima.org/4th-generat...ough-hell.html
http://forums.maxima.org/4th-generat...0-4500rpm.html
Old Oct 11, 2008 | 03:53 PM
UncleMax98's Avatar
I had a bad MAF before. The car power cut out for a few seconds once in a while. The car drove great in between. I could drive for a few days without problem. This problem went on for weeks, but I did not know what to fix. Eventually it got so bad that the MIL was on with bad MAF code. I replaced the MAF with a used one from Ebay. No problem since.
Old Oct 12, 2008 | 10:12 PM
ruckus1027's Avatar
hmm i was thinking maybe a intermittent faulty knock sensor? i could be totally wrong but i remember reading something about a knock sensor that only functions intermittently...maybe its not tripping a code for knock sensor because of that...but im going out on a limb here..so yeah i could be totaly wrong lol
lowpost99
Oct 26, 2025 06:53 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
