Wires from under the hood to inside the car
Old 10-12-2008, 08:27 PM
Still Learning
t65k3's Avatar
I am trying to put on some LED fogs with a switch so that they can be lit seperately. They are now hooked up in parallel with the sidemakers. However, it might be "cooler" if I could have only them on sometimes.
I need to pull wires from under the hood to inside the car so that I could put up a switch just for it. I tried to locate some kind of a hole or a little space I could slip it through with cables that's originally there, but I could not. Any idea? I don't want to just pull it around the side of the door and have the wires exposed.
Pardon me the question, I tried "search" but I didn't get what I needed. Probably I didn't use the suitable keyword for that.
Thanks~
t65k3 is offline
Old 10-12-2008, 08:40 PM
No more Maximas...
pmohr's Avatar
If you search 'firewall grommet' there are many hits that detail places to go through the firewall.
Why not just go through the engine control harness grommet? That's the largest and it's fairly easy to get to.
pmohr is offline
Old 10-12-2008, 11:40 PM
Still Learning
t65k3's Avatar
Thanks, bro. I found what I needed by searching "firewall grommet" like you suggested. Appreciate the help~
t65k3 is offline
Lakersallday24
06-16-2019 01:35 AM
Viralkill
08-16-2015 05:09 PM
doobadoo
08-15-2015 06:43 PM
altome15
08-10-2015 07:05 PM
erniel
08-08-2015 09:32 AM
Quick Reply: Wires from under the hood to inside the car
