Flip Flop Trunk
Old Apr 13, 2005 | 06:41 PM
I30_DRIVER's Avatar
Flip Flop Trunk
i was wondering if anyone can do a write up on hot to do a flip flop truck
would be great with pics..
thanks
Old Apr 13, 2005 | 06:53 PM
Black Maxima
HAHAHA I hear 03on18s has a good write up for it. HAHAHA I'm just kidding...
Yea, I would like to see a write up for it also!
Old Apr 13, 2005 | 06:54 PM
DRIFFT MAX
Oh snap son!
Old Apr 13, 2005 | 07:03 PM
CleanMAX98's Avatar
hahahahahahahaha more like the flip-flop-smash trunk!!
Old Apr 13, 2005 | 07:10 PM
Black Maxima
Hey you got a flip flop trunk. Tell us how you did it...
Old Apr 13, 2005 | 07:12 PM
sunten1
DAMN! I had that guide thing too, it was saved on my computer...but I can't find it...sheit I must have deleted it
Old Apr 13, 2005 | 07:21 PM
CleanMAX98's Avatar
thats crazy talk i dont have the flip flop trunk
Actually Ed (Erty67) did it for me, he has been a big help im sure he would be glad to do the write-up , if not i will try just give me a few days
Old Apr 13, 2005 | 07:22 PM
CleanMAX98's Avatar
oops my plate is showing
o-well!!!
Old Apr 13, 2005 | 08:30 PM
86maxima96's Avatar
I Broke OT
yeah, if anyone has a flip-flop trunk write up for a clean looking job, that would be pretty cool.
Old Apr 13, 2005 | 08:33 PM
DRIFFT MAX
Time to stalk. lol
Old Apr 13, 2005 | 08:35 PM
CleanMAX98's Avatar
ill take pics and do a detailed writeup tomorrow
Old Apr 13, 2005 | 08:53 PM
86maxima96's Avatar
I Broke OT
yay! i love the org!!
Old Apr 13, 2005 | 09:03 PM
CleanMAX98's Avatar
http://www.vqpower.com/v2/modules.ph...showpage&pid=7
CleanMAX98's Avatar
its not too descriptive so ill make a better one i guess
Old Apr 13, 2005 | 09:05 PM
MSmax96's Avatar
Why wait for tomorrow! when i can do it right now....
Old Apr 13, 2005 | 09:29 PM
I30_DRIVER's Avatar
10x its great but no pix of bends or any of that
so if anyone can please
Old Apr 13, 2005 | 11:29 PM
pavelsmax's Avatar
anyone with the flip flop and subs in the trunk notice more rattiling (spell) i wanted to do it as it looks good and cheap but i worry about it making more rattiling that my max doesnt need
Old Apr 14, 2005 | 06:38 AM
craig10114's Avatar
evan (03on18's) sells kits to make the flip flop trunk..... and everyone whos bashing on him in here, that very very easily could of happened to anyone, hell it happened to me while just attemping to make my own flip flop trunk, so give the guy a rest its over and done with and the window was replaced. and cleanmax come on man, you 2 already had words about this **** and you just make a comment in another thread? not bashing you for it at all or trying to be an "e-thug".. just my .02
Old Apr 14, 2005 | 08:43 AM
erty67's Avatar
Decal Specialist
The way I did mine, I didn't use a "locking latch" to hold it in it's normal position. Instead I still use one of the 10mm bolts on each side. Realistically, you don't use the flip-flop option that often. Doing it my way allows you to keep the trunk tightly fastened so extra rattle doesn't exist. I also didn't use screws to attach the hinges. I used rivots. It gives it a much cleaner look. (not that you really see it anyway) Then when you are at a meet/show, you just take the two 10mm bolts out with a wrench or socket. I did mine in under 30 minutes and CleanMax98's in under an hour. (we had a problem with drill bits and had to make a Home Depot run) Mine has been this way for 2 years now and it's still holding up perfectly. I'll try to do a write up doing it the erty way with pics when I'm home later.
Old Apr 14, 2005 | 08:47 AM
erty67's Avatar
Decal Specialist
here's a pic from the good ol' tezza days....
^^page 2 on my homepage^^ stinking Cardomain
Old Apr 14, 2005 | 08:55 AM
erty67's Avatar
Decal Specialist
OH SNAP! I still have a pic on my webspace! Read my description two posts up and look at this pic. You can see where the paint scraped off the bolts I'm using fromtaking it in and out. Rivots are hard to see, but they are there. Also, I bent the hinge by screwing it down to a board and hammering it to that form. Get it? Post questions if needed.
I've since painted that black, so it blends in.
Old Apr 14, 2005 | 09:33 AM
97maxxx's Avatar
yea about the noise-mine rattled more when i had the flip flop trunk-so i took it off-if you have a big system then i would say not to do it but thats just me
Old Apr 14, 2005 | 05:13 PM
erty67's Avatar
Decal Specialist
The ERTY way....
1st, I got two 3" hinges from Home Depot and formed them to fit. I did this by holding the hinge up to the support and marking where the 90 degree bend goes with a marker. I then screwed the hinge down to a board and bent it using a hammer. Then I bent the other side of the hinge slightly to fit the mold of the trunk lid. You can see this in pic #1. Also notice I had to redrill the holes on the 90 degree bent side. Pic #2 just give a full view of the hinge. Pic #3 points out that I still have the bottom 10mm bolt in place. I never took that out while installing the hinge. This made it easy to hold the trunk into place. LOL Then I used a 3/16 drill bit to drill the holes, while putting a 3/16 rivot into each hole as I drilled it. The holes in the hinge are already 3/16. After that, I did the same thing on the other side. This is basically the whole job.
Next, take out the two remaining 10mm bolts while holding the trunk lid up with your other hand. You want to be careful not to drop the lid into your back window. Once both are out, the trunk lip will swing. Notice pic #4
That's it. You're done! When you want to go back to stock mode, just put the two 10mm bolts back in and it's back to normal.
Old Apr 14, 2005 | 05:18 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
instead of ribbets on both holes on the top hinge, I put a bolt sticking out abit so the trunk doesn't go all the way down like that.... pic, notice mines is straight not facing down....(this is my old car)
Old Apr 14, 2005 | 05:24 PM
Max Mutes's Avatar
Nice write up Erty, very nice. Just one thing. If you have already screwed in all the screws into the newly drilled holes on the hinges such as in Pics #3, then when you take out the 2 10mm bolts you would no longer need to worry about it falling since it is already fastened tightly correct? or no? lol that's the only part that confused me a little.
EDIT: Ay Tek, so you put a bolt in this top hole on the top hinge here in Pic 2?
I would think the top hole on the lower hinge section would be more of a bumpstop for it to sit even, but I guess not...that's a good as* idea tho.
Old Apr 14, 2005 | 05:27 PM
Tek-Niq's Avatar
I did the same thing, just put the bolts back on and it will close normaly... when you take them out is when it flip flops...
Old Apr 14, 2005 | 05:29 PM
erty67's Avatar
Decal Specialist
no screws....rivots It is secured as in the trunk lid won't fall off, but if you aren't holding it up when you take the 10mm bolts out, it will swing into the back window. The two 10mm bolts are what hold it into place when you don't want it to flip.
Old Apr 14, 2005 | 05:33 PM
Max Mutes's Avatar
Ahh I see, I see. So if I was to do a bumpstop type bolt thing like Tek...then I should have no worries of it swingin into the window I guess.
Old Apr 14, 2005 | 05:42 PM
Tek-Niq's Avatar
yep you won't have this problem...
Old Apr 14, 2005 | 08:11 PM
CleanMAX98's Avatar
tek can u explain how you made it to stay straight up i am a bit confused
Old Apr 14, 2005 | 08:13 PM
DrTySOUFMaX23's Avatar
y would u wanna flip flop trunk anyways?? i mean no offense but i think it's just a waste of time and it's gay...
Old Apr 14, 2005 | 08:27 PM
CleanMAX98's Avatar
cool! thanks for your opinion, by the way nice car!!! what kind of rims are those and what do you have for a drop???
and what rear kit is that???
Old Apr 14, 2005 | 09:57 PM
I30_DRIVER's Avatar
great write up you should put it in stickies i will try to perform this on sunday
and for the guy with a cracked window how did you manage to do that????
Old Apr 17, 2005 | 09:59 PM
I30_DRIVER's Avatar
any pics of guys with latches
Old Apr 18, 2005 | 03:10 PM
ti2tmax's Avatar
Has his VINs memorized
Do you have any exact info on the Home Depot hinges you used? I tried to find some and couldn't....was gonna try it with smaller hinges and a brace, but that just looked riced so I didn't even bother trying.
Old Apr 18, 2005 | 03:45 PM
97maximaman's Avatar
is there like...an actual purpose to a flip flopper.
Old Apr 18, 2005 | 03:53 PM
Tek-Niq's Avatar
I'll try.. if you get the proper hinge and install it, you will find that when the trunk is down in a flip flop way one of the hinge holes end up right where the trunk arm meets the lid...
what i did was put a threaded rivot for a screw in that hole.. so when down you can adjust it by simply screwing the bolt in or out...
Old Apr 18, 2005 | 03:54 PM
Tek-Niq's Avatar
no.............. tell you the truth I regret doing it to my max...
Old Apr 18, 2005 | 04:18 PM
ti2tmax's Avatar
Why do you regret it? I think the look really sets it appart especially the way yours is set up. I don't think there are any cars in this state(Maine) that have a flip flop trunk. We are technologically WAAY behind the rest of the US.
Old Apr 18, 2005 | 04:25 PM
Tek-Niq's Avatar
too ghetto for me..... and the trunk lid won't close the same.. you have to do it to understand how it throws the lid off.... you need to install those latches or keep the oem bolts for a reason, nuff said..
