Reseting ECU ?
Old Apr 17, 2005 | 04:32 PM
FormorAccordMan's Avatar
Reseting ECU ?
When disconnecting the battery to reset the ECu, how many hours must the car sit?
Old Apr 17, 2005 | 04:37 PM
Zack342's Avatar
mike best bet is going to Autozone and asking one of the guys to reset it or you could try doing it manually via the ECU. i don't recommend ecu method since we have 99's with a small screw.
I am pretty sure disconnecting battery doesn't clear codes since i tried this a while back when i had my O2 sensor code.
Old Apr 17, 2005 | 04:40 PM
Hmm, well I am not really clearing codes per se. I dont have a CEL and Autozone wont come out to your car unless you have a CEL. My car is sitting disconnected and dead to the world as I type. BTW, thanks for your help earlier today.
Old Apr 17, 2005 | 05:11 PM
ewuzh's Avatar
Disconnecting the battery does NOT reset the ECU. I tried to reset it this way, but it does not clear codes.
To correctly reset the ECU, look under your dash (behind the center console) and find the ECU unit. There's a little screw you can turn with a flathead that is facing the driver's side. Turn your ignition to the ON position (don't start the car). Turn the screw all the way clockwise (to the right) until it doesn't turn anymore. Hold and wait 2 seconds. Turn the screw back all the way counterclockwise and hold for 2 seconds. Repeat the process again and you will hear a bit of electronic noise come from the ECU (telling you it's resetting itself).
Old Apr 17, 2005 | 05:16 PM
The 99SEL's ECU screw is small and recessed. It's a Pain in the ****. But I guess thats the only way.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
