flickering fog light
Old Apr 23, 2005 | 01:51 PM
VQ30de96's Avatar
my fog light tends to turn on and off. for the most part the light remains off, and goes on when i open and close my hood? the bulb was recently replaced and i'm not sure that the bulb is going. it could be, but anyone else have this problem please gimme some help! thanx!
Old Apr 23, 2005 | 01:52 PM
sunten1
So your saying that they go on and off by themselves? WHOA! They must be possesed.
Old Apr 23, 2005 | 03:08 PM
Ruthless's Avatar
It does not seem like a faulty bulb. They either work or dont work. Since I have some circuit schoolin behind me, I would consider checking for a blown fuse that is kinda intact (partial circuit) aswell I would check for loose/ busted wires. That could definitly be a cause of the intermitent connection. Aswell, taking a volt meter and measure the voltage of the wires going to the fog lights themselves could also help determine if the problem is with the lights themself. Try disconnecting one fog light.. see what happens, then try the other
my 0.02
Old Apr 23, 2005 | 03:18 PM
MDeezy's Avatar
Yea what ruthless said. Just sounds like its not fully plugged in propely.
Like if you screw in a light buld but screw it in just barely, the slightest movement will cause it to flicker on and off. Sound like it could be the case for you.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
