spring rates?
Old 05-10-2001 | 11:10 PM
maxium nrg's Avatar
hi, i was wondering if someone could explain spring rates to me? specifically what the numbers mean? does a higher number mean a softer ride or vise versa? thanks
Old 05-10-2001 | 11:24 PM
Nealoc187's Avatar
SLOW
spring rate
a spring rate, such as 450 lbs/inch... means it takes a force of 450 lbs on the spring to depress it 1 inch. so if you were 225 lbs and you stood on your spring without falling off you would depress it 1/2 an inch.
Neal
Old 05-10-2001 | 11:33 PM
vmok's Avatar
so the lower the number the softer the spring.
the other thing to remember is that the higher the spring rate, the harder it is for the strut to control the energy of the spring, sometimes necessitating a change to a strut capable of handling the spring rate.
btw, it's pretty hard to balance on a spring without falling off, so be careful when you try it.
-V
JakeOfAllTrades
10-29-2024 06:55 PM
MaxLvr21
10-17-2015 12:11 PM
MaxiNoob98
10-02-2015 10:13 PM
JakeOfAllTrades
09-30-2015 03:16 PM
followthadollar
09-27-2015 01:06 PM
Quick Reply: spring rates?
