Tranny Help before i drive it again Want to Know if is okay to drive!!!!!
Old Apr 26, 2005 | 05:52 PM
CleanMAX98's Avatar
my tranny sounds funny, while stopped and proceeding to go into first my tranny(5speed) make a weird noise like when you first try and start a lawn mower but in a very dull low tone kinda like a rock rolling or something then after it makes that noise it makes a noise like a squeaky kitchen cabinet hindge, but it goes away after 2 or 3 seconds, i went home and looked under the car and the part of the tranny that is closest to the driver side fender had black stuff caked on it i have no clue what is going on and thought you maxima experts would know
please help thanks
Old Apr 26, 2005 | 06:10 PM
MDeezy's Avatar
*Check your resevoir and see how much fluid is still in there.
*Do you hear the noise when you ONLY clutch in? or When you clutch in and try to put it in gear?
*The squeak could be that shaft behind the clutch pedal itself getting dry and in need of lubricating. Maybe get down by the pedal listen with youe ear and push in the pedal by hand (of course if the noises you hear are when you only clutch in).
Maybe something above can help. I know when trying to extend the life of a potentially dying/wounded tranny (clutch maybe). Adjust the grab point (clooser to the floor) and a bleed can work wonders also.
Old Apr 26, 2005 | 06:53 PM
CleanMAX98's Avatar
i just got a brand new tranny 1,000 miles ago, it doesnt make the noise when the clutch is in, it makes it while i am proceeding from a stop in first, the squeaky noise also happens when you jump the gas while in first only under 3k though its weird, i just went to pick up my bro and the noise is gone, its weird!!!! and annoying!!! thanks for the imput
Old Apr 26, 2005 | 07:13 PM
MDeezy's Avatar
did you get your clutch changed at that time?
if so did you break in the clutch ?
edit: if you got it installed only a 1000 miles ago everything should still be underwarante, It maybe a good idea to take it back to where you had the work done and have them check it out, if you havent dont anything abusing or just done normal driving since you got the tranny it could just be an install error.
Old Apr 26, 2005 | 07:50 PM
CleanMAX98's Avatar
ya i laid off the clutch for 300 miles and i only drive it hard like 3 times a day for a minute or so
Old Apr 26, 2005 | 07:54 PM
MDeezy's Avatar
your really suppost to baby its for the first 500 mile and then after that you can be harder on it but not before then. Not to say that your situation now is a direct result of it but it could be the issue in this case.
If your hearing noises and such, it could be you got a bad tranny, which would be covered under warantee and you should get a free rebuild, or something was installed incorrectly. I'd try taking it back to the shop and get them to look at it.
Old Apr 26, 2005 | 08:05 PM
CleanMAX98's Avatar
thanks for all your imput ill get it looked at tomorrow at my indeoendant shop so my dealer has nothing to bullshyt cuz i got the hard facts
Old Apr 26, 2005 | 08:08 PM
MDeezy's Avatar
no prob and good luck
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
crazyespn
Sep 3, 2015 01:30 PM
Lowered_a33
Sep 1, 2015 07:49 PM
