Arghh car misfires 4 days after I buy it!!
Old Apr 27, 2005 | 12:41 PM
maximizd97's Avatar
So I need some help here...just paid a ****load on my new max and am feeling poor as hell. Now my SES light is on, and codes read "cylinder 6 misfires", and ignition malfunction. I assume this is a fuel/spark issue that has affected cylinder 6.
What are some common parts that could have gone out that would cause this? My best guesses were plugs, injectors, or coils. Also, if I haven't started the car in a while, it wont fire up til the second try...not cool!
I think the problem may have been because I used premium gas from a pump that was no joke at least 30 years old, and in the middle of rural Iowa where I'm sure no one uses premium anyway...
How can I remedy this problem in the cheapest way???
Old Apr 27, 2005 | 12:47 PM
Maxima99SE's Avatar
will fly for food
you have a 99 so replace your ignition coil packs.
Old Apr 27, 2005 | 12:49 PM
BlueC's Avatar
wat
Bring it back to the dealership you bought it from. I know up here, if something goes wrong within 30 days, they are liable for the repairs. This is a good opportunity to get them to replace the coil packs for free.
Old Apr 27, 2005 | 12:55 PM
crapsack's Avatar
Believe me its the coil packs, you got a 99 and the same thing happened to me and plenty of other people
Old Apr 27, 2005 | 01:31 PM
njmaxseltd's Avatar
It's you coils, but your lucky. Your ECU picked up the cylinder with the bad coil. Start by replacing cylinder #6 coil pack and your misfire, if your luck, should go away.
If you continue to get a misfire, or your engine surges, replace the remaining 5 coil packs. Unfortunately the 99's are known to have a ton of coil failures.
Old Apr 27, 2005 | 01:47 PM
Mr.Duck's Avatar
yea, its the coilpacks, one of mine went out a couple of months after i bought my car also, at 30k miles! that just pissed me off, lol oh well got it replaced no biggy, they are a bit expensive though...
Old Apr 27, 2005 | 03:56 PM
maximizd97's Avatar
Well that sucks...I bought it private so I can't do much...is there any service bulletins on 99's? I've had cars where they pay half the repair for service bulletins.
Old Apr 27, 2005 | 04:26 PM
Jatan's Avatar
You have to pay full price for service bulletin repairs (unless you're still under warranty). Only recalls are free.
Either buy a used set from eBay and keep the rest as spares for the future or just buy some new ones...
Old Apr 27, 2005 | 04:29 PM
BK1's Avatar
BK1
Hello
What's the difference in coil packs between 97-98 and 99??
Bobo's Avatar
Are coils for a 99 Maxima something that can be picked up at an autowrecker?
Old Apr 27, 2005 | 04:59 PM
killerVQ30DE's Avatar
Dodgy Seller?, sounds like they might have scammed you
What are the chances the Stealership has reset the ECU which cleared the code, and came back 4 days after you owned it
Old Apr 27, 2005 | 05:13 PM
Jatan's Avatar
You can try this out if you want to (write up all the way in the end): http://forums.maxima.org/showthread.php?t=389309
95-99 are the same. Nissan was switching manufacturers or something for the 99s (maybe late 98s also) and they didn't turn out so great... Nissan doesn't want to issue a recall so you gotta pay out of pocket
They should have them or you can check eBay for used ones
He bought it from a private party (read a few posts up) so either the seller had it reset or it just happened for the first time right now
Old Apr 28, 2005 | 03:35 AM
BK1's Avatar
BK1
Hello
Are replacement coil packs from the dealer the crappy ones or the good ones? I mean, did they go back to the good manufacturer?
Old Apr 28, 2005 | 06:09 AM
Jatan's Avatar
I think they fixed the problem with the coils going bad, but you can look at what brand your coils are and buy the other brand instead (Nissan has Hanshin and Mitsubishi but someone mentioned that they might be getting rid of one of those)
I would personally just buy a set from eBay and keep the rest as spares just incase other coil packs go bad later on...
Go try this out and see if it does anything http://forums.maxima.org/showthread.php?t=389309
Old Apr 28, 2005 | 08:00 AM
maximizd97's Avatar
So will only the hanshins work for my 99? Or could I use any coil pack from 95-99? I found a used set for a 97 so I want to know if these would swap in.
Old Apr 28, 2005 | 08:47 AM
Ninos_Maxima's Avatar
be the change u want2C
yeah go read my beta. it should fix your woes, but you need a lot of elbow power, and dont be afriad of blisters. Im trying to make a fuse between sparkplug wires and our coils. But all 95-99 coils are interchangeable.
link to beta http://www.jatan.net/CoilsBeta1.doc
Old Apr 28, 2005 | 09:51 AM
adampecush's Avatar
im new to the whole maxima forum, so i cant submit a new post....so i'll just add to this one. I'm guessing i have a coil issue, as at high(er) rpm (3250+) i get a loss of power/misfiring along with what sounds like backfiring (sharp popping) I initially passed this off as bad gas and i was just pinging/knocking, causing timing to be pulled, hence the loss of power. I just put a new tank in and the problem persists. The car is perfectly fine under low load conditions. I threw a code yesterday, which caused the check engine light to blink for a while, but not stay on. I guess i could go check codes, but im wondering if this is what it feels like to have coils that are on their way out. Oh yeah, the car is a 99.
edit: apologies for the apparent hijack...pm'ing responses would probalby be the best so i dont tie up this thread with useless info for the original poster...
Old Apr 28, 2005 | 11:08 AM
Mr.Duck's Avatar
hey it might be your knock sensor, you might want to go check that out.
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
egali045
Aug 5, 2015 09:02 AM
yat70458
Aug 3, 2015 01:16 PM
